Coolant?
Coolant?
I want to top-up my coolant level a bit before I have my garage do a flush-n-fill in a couple more months.
Prestone sells "Prestone 50/50 antifreeze and coolant" which they state is "compatible with any antifreeze/ coolant - regardless of color - for use in all makes or model of cars and light duty trucks." It is "demineralized water and ethylene glycol" with "no nitrates or silicates."
What do you think?
What do you think?
Mixing coolant types can cause gelling. If you just need a top off use distilled water. Since your car is a 2006 your car is already past due for a change if it hasn't been done. If you have a DB9, its surprisingly easy to do a coolant change. Search this forum for my DYI write up, if you feel brave.
