Bumpers upgrade
#46
x-chr
#48
@Era2076 : The seat memory switch don't work. I can't move the seats.
I can't find where to buy the connector to plug in this :
@Vince_1972 : merci Vincent, je ne t'oublie pas ! Si je n'arrive pas à faire fonctionner les sièges en version origine je les installeraient en position fixe via des platines en aluminium et le boitier qui va bien pour supprimer le défaut Airbag ;-)
#56
I order a pair of RECARO seat track, they weight only 2,5kg
Does I use the OEM electric track or the manual RECARO one ?
With the RECARO one I can reduce the total weight arround 15,5kg (33.07lb)...
#57
x-chr
#60
You have here the combined effect of 2 changes:
1. Memory adjustment seat vs stock adjustment seat
2. Lightweigth seat frame vs stock seat frame
1. makes all the differences with the connectors etc. I think the memory also has a separate "brain" (storing the positions) which needs connecting.
2. I wonder if you could not simply swap the seat carrying structure from the lightweigth seat frame to the stock seat frame and thus use your old frame & adjustment? Just a thought...
Thomas
Thomas
