Left Key in ignition
Old 09-08-2016 | 01:42 PM
seastu's Avatar
seastu is infamous around these parts
Left my key in the ignition over night with accessories off ( 2016 Vantage) Car was on a battery tender. In the morning it showed very low charge. Re charging now just wondering if I messed anything up.😁😁😁
Old 09-09-2016 | 08:48 AM
GDay2's Avatar
GDay2 is a jewel in the roughGDay2 is a jewel in the roughGDay2 is a jewel in the rough
The battery tender is not really a charger it is meant to keep the charge at level. It only supplys 0,8 Amp which obviously was not enough to eaqual the drain by leaving the key in. I would say that there is no malfunktion of the car or tender. Drive the car for an hour to recharge the battery and it'll be fine.
Cheers
Christian
Old 09-10-2016 | 04:03 AM
seastu's Avatar
Christian
Old 09-11-2016 | 09:09 AM
captain Greg's Avatar
captain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to behold
Scuse my ignorance? Does this mean you left the key in its slot? Or just lying in the car?
I leave mine in the center console for weeks and it just fires up when I call for the Aston moment (not often anymore cos they are real low)
Old 09-12-2016 | 07:04 AM
embdenb's Avatar
embdenb has much to be proud ofembdenb has much to be proud ofembdenb has much to be proud ofembdenb has much to be proud ofembdenb has much to be proud ofembdenb has much to be proud ofembdenb has much to be proud ofembdenb has much to be proud of
I would assume he left the key in the ingnition " slot", which continues to sent current to the radio and I suspect other stuff.
Old 09-12-2016 | 02:48 PM
AXARUNNER's Avatar
AXARUNNER is a splendid one to beholdAXARUNNER is a splendid one to beholdAXARUNNER is a splendid one to beholdAXARUNNER is a splendid one to beholdAXARUNNER is a splendid one to beholdAXARUNNER is a splendid one to beholdAXARUNNER is a splendid one to beholdAXARUNNER is a splendid one to behold
I too made this mistake... I had to jump the car but no harm was done.
Ktw
09-10-2016 03:08 PM
lstoker
09-05-2016 08:27 AM
Quick Reply: Left Key in ignition
