Coolant revisited
Disclosure since I sell the stuff: I signed up with Motul for engine oil and brake fluid. The fact that the coolant is so well aligned was entirely luck. Also got lucky with their gear oil since it's the closest to the BOT270A's specs that I've found, but far less expensive.
Evans has many advantages but may not be the best choice if your use puts lots of stress on the cooling system i.e. towing, track time.
BTW, Jay Leno has a very qualified, full time staff that looks after his cars.
Has anyone added Water Wetter to the coolant? When I built a supercharged Corvette I used Water Wetter to the coolant to help reduce the temperature. It was recommended by the shop that did engine build and also by the supercharger manufacturer. It seemed to work because I never had any cooling problems even in our hot Florida summers.
I've found that Chevron Delo XLC has the same listed ingredients (and color!) as the Havoline and the Motul that both don't seem to be available any more. I use the same stuff in my Lotus so I bought 4 concentrated 1 gallon bottles on Amazon for $80 to cover both cars. So $20/gal, not too bad.
https://cglapps.chevron.com/sdspds/S...&docFormat=PDF
Good info! This is full strength and needs to be diluted 50% right?
I'm currently using the Motul, any idea if we can mix the Chevron with Motul? Might be replacing some coolant hoses so may need to top up and don't know if I will have enough Motul left. How many miles/years are you all flushing your coolant? Thanks!
Makes sense. It seems to only be for sale on ebay and Amazon. I only saw one version of the XLC on Amazon (seems like it's the full concentration version):
https://www.amazon.com/Delo-XLC-Anti.../dp/B073VZ5X89
I have a hard time finding the OEM coolant Havoline OAT. and the (almost identical) substitution Motul Inugel Optimal Ultra (recommended by Redpants and others) seems to be discontinued.
Of all the alternatives the Chevron Delo XLC looks like the next best fit to me. Any know issues with using this coolant, mixed with 50% water for a complete flush for a 2014 Vantage V8?
