What did you do to your Aston today?
Old 12-19-2017 | 09:14 AM
Smoky's Avatar
Smoky has much to be proud ofSmoky has much to be proud ofSmoky has much to be proud ofSmoky has much to be proud ofSmoky has much to be proud ofSmoky has much to be proud ofSmoky has much to be proud ofSmoky has much to be proud of
VelocityAP twin disc clutch and lightweight flywheel install complete! And it is AMAZING! The pedal is so much lighter now, and the clutch action is quick. Engagement seems to be just about where it was before, which is fine. It is SO much easier to drive the car smoothly now. What a difference! This is how it should have been from the factory!
Huge thanks to Stuart at VelocityAP for working with me on the kit, and to Vinnie Carollo of VEX in Baton Rouge for another flawless install.
Old 12-19-2017 | 11:18 AM
blue2000s's Avatar
blue2000s is a jewel in the roughblue2000s is a jewel in the roughblue2000s is a jewel in the rough
I'm surprised to read that you are concentrating on the pedal force and engagement instead of talking about changes in the engine behavior. Is it because the difference is not significant?
  #198
Old 12-19-2017 | 12:17 PM
Smoky's Avatar
Install was only completed this past weekend, and it's been raining since. Not a lot of miles on the new setup yet.
I did mention it is a lot easier to drive smoothly now, I guess I could have been clearer about that. All based on my 1+ hr drive home from the shop....Rev matching on downshifts is WAY easier to get right now. Stop/go is much smoother now with the stronger clutch and lighter flywheel. Engine definitely feels lighter in terms of rpm inertia (on shifts and an on highway decel).
Will share more impressions as I put on more miles. But so far I would say this mod is a win. If you are getting to need a new clutch anyway this is definitely an option that should be considered rather than a straight oem replacement.
I can say that when I got home that day I had the same excited butterflies as if I had just taken delivery of a new car. It is definitely an exciting mod.
  #199
Old 12-20-2017 | 10:59 AM
squiddie's Avatar
squiddie is infamous around these parts
Originally Posted by HabitualOffender
With everybody doing fun winter projects this doesn't really fit in the thread, except, I had to do this to my Vantage LOL
Emergency funeral, I always park on the roof, had no time to check the weather report.
20 minutes, no gloves, thin jacket, plowed in, and bald tires on the back!
I hope you don't have performance compound tires on there? They might fall off in chunks when it gets cold enough.
  #200
Old 12-20-2017 | 11:37 AM
brightoncorgi's Avatar
brightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond repute
I backed my car out of the garage for some contractors to do some work. Getting an Aston Martin sign (just the lettering) installed to a wall.
  #201
Old 12-20-2017 | 12:03 PM
blue2000s's Avatar
I have an AMR clutch sitting on the shelf waiting to go on in the spring. The AP tune that I bought last spring did such a great job of waking up the engine. Throttle response at low RPM improved noticeably, heel-n-toe can be accomplished quite a bit faster and the engine is much more eager to rev in the low to midrange. It has absolutely improved the responsiveness of the engine and I was starting out with a power pack car, which was supposed to be better than the stock 4.3 already. Now I have to install the FW and clutch to see how good it can get even though my clutch seems fine so I'm always interested in hearing the results that others have experienced with the updated clutch.
  #202
Old 01-05-2018 | 11:15 AM
silver997's Avatar
silver997 is infamous around these parts
EGR delete installed
Headers done. Finally!
Not much room in there!
Oil change
Name:  OIL CHANGE 1.jpg
Name:  OIL CHANGE 2.jpg
Name:  OIL CHANGE 3.jpg
  #203
Old 01-09-2018 | 10:57 PM
Gene G's Avatar
Gene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond repute
How hard was the header install? Any noticeable power increase with the headers? Not just dyno numbers but seat of pants feel.
  #204
Old 01-10-2018 | 08:47 AM
Old phart's Avatar
Old phart is a jewel in the roughOld phart is a jewel in the roughOld phart is a jewel in the roughOld phart is a jewel in the rough
+1 on that header question. Looks really tight down there.
  #205
Old 01-10-2018 | 09:37 AM
silver997's Avatar
I did the install on jackstands. It was very time consuming. My car is parked for the winter so I could take as much time as required. I would not want to do this myself if I was under any type of time crunch. After researching the job I was really worried about the nuts and bolts that attached the headers to the block being flimsy and easily stripped. That was not the case. The nuts and bolts are very robust. Frankly, it was kinda a nightmare. You need to use a different approach to access every bolt. Swivels, extensions, wobbley, wrenches......
I did run the car with the new headers installed with the cats that were installed in the summer. It's louder. I can't drive my car until spring. I hope with the tune, headers, and cats it will be worth the effort.
I won't be able to give any real feedback on the mods until I can really drive the car. That will be about 3 months from now. If you believe what the vendors are saying.....
ECU tuning 30hp
Cats 10hp
Headers 10hp
I should "feel" 50 hp?
  #206
Old 01-10-2018 | 02:22 PM
Dalecannavan's Avatar
Dalecannavan is a splendid one to beholdDalecannavan is a splendid one to beholdDalecannavan is a splendid one to beholdDalecannavan is a splendid one to beholdDalecannavan is a splendid one to beholdDalecannavan is a splendid one to behold
Can you expand a little on why you did the EGR delete? Also, will it not affect emissions?
  #207
Old 01-10-2018 | 03:21 PM
silver997's Avatar
Please read.....
HTML Code:
https://www.6speedonline.com/forums/aston-martin/389883-egr-delete.html
I really struggled to remove that pipe. AFAIK you can't remove it without having the RHS header half way out ! I considered just cutting it off. Yea, removing it was a real PITA. I didn't want to put it back in.
I bought a tune from VelocityAP. I will request that this is modification is installed, they can tune for it.
  #208
Old 01-11-2018 | 08:43 PM
Old phart's Avatar
Had my wheels repaired and refinished. Fronts had some flat spots from potholes. Went darker to hide brake dust. Any tips on how to keep them shiny and new? Ordered new center caps but got the silver. Might try to darken them a bit to match.
  #209
Old 01-13-2018 | 06:25 AM
Simonhaddow1's Avatar
Simonhaddow1 is infamous around these parts
This weekend, replacement clutch & flywheel.
  #210
Old 01-13-2018 | 06:29 AM
Red vent detailing, 5 minute job
I've darkened the photo out to bring out the red.
