Parking Brakes (help)!
Hi all. So I have a problem, can't get the parking brakes back on! I replaced my rotors with the lightweight two piece Wilwood rotors today (ordered from Redpants). New pads on the main rotors were no problem. But with the new rotors I could not get the parking brakes back on. Seemed like the more I tried the more the piston pushed out. No way to fit them on now, even with the old worn pads.
Any suggestions?
By the way, screws holding the rotors on suck! Had to chisel all of them out! Rotors needed a lot or persuasion by a huge red rubber mallet to get off too.
Any suggestions?
Parking brake special tool
I had the same issues when I installed the two piece rotors over two years ago.
Rewinding the parking brake piston can be a challenge, as clearances are rather close when the calipers are assembled.
The workshop manual in Installation step 2 calls to "Retract pistons into calipers (special tool?)"
See Installation instruction #2.
I separated the two halves of one of the parking brake calipers. You can see the two holes in the top of the piston which are used to rewind the piston.
Two holed piston face
I made up a simple fixture using a flat washer, a nut and some rod material that I had in my garage-it took me about an hour to fabricate after I decided what needed to be done.
Only two holes needed to be drilled and the assembly was all press fit.
Piston side
Wrench side
Rewinding piston
The second question was how can I insert the fixture between the caliper body and the parking brake piston while still assembled?
After some failed attempts, I ended up using a tie-wrap around the washer which provided a "handle" and was thin enough to allow the wrench to fit as well.
The combination worked well enough on the other side that I didn't need split the parking brake caliper.
Side view
Top view
It probably took longer to make the fixture than to disassemble the second caliper, but if there is a next time, I'll be ready .
Piston side
Wrench side
Rewinding piston
Side view
Top view
Guy's thanks for the advice. It was actually very easy once I knew the simple process of screwing in the piston in. It should have been obvious.
The new Wilwoods and pads purchased from Redpants are great! Smoother braking for sure. I know it's in my head but the car feels lighter.
I used small vicegrips, clamped down in the center area of the pin. Then use a hammer to tap grips close to the jaws outward just as the tip with the retainer clip comes out. Then repeat with the other's.
