Broken radiator and disintegrating fans
Honestly I would be extremely surprised if it did not communicate correctly. After all our fans use a Jaguar fan setup. Here's an example: The OE provider (Bosch) stopped making fans (and modules) in 2012 for the BMW e46 chassis. I tried aftermarket fans (and modules) in two cars and they were junk. I started using Bosch fan modules that were in certain Mazda, Ford and Volvo vehicles that carried a similar Bosch part number. I've had two in a couple of bimmers now going on 5 years - no issues. On those I had to splice the BMW harness (pigtail) connectors at all the connections cause the Mazda, Ford and Volvo used different connectors than BMW. You won't need to even do that since the fan connections are Jaguar cause it's actually a part for the Jaguar fan. The only connector that could theoretically be different is the 3-wire connector coming from the ECM - but I think the odds there are even 100/1 against cause it plugs into the same module. The inner workings of these are simple - they control fan activation and speed based upon the PWM signal (whihc is just a square wave on/off voltage signal from the ECM - all the complex logic is pretty much in the ECM.
Confirmation. The Jag fan and controller is a direct fit, and works perfectly, no wiring connector changing needed.
Great news, I am currently waiting for:
Enough to be busy while the parts are on their way.
I will keep everyone updated on the result.
- Coolant sensor
- Used fans
- Used controller
- Gear oil
- Brake oil
- Air filters
- Power steering oil
- Thermosthat
- Oil catch can
- PCV Valve
- Idler pulley with new belt
- Engine oil
- Porterfield brakes
It's down beneath the throttle body housing - Remove the accessory belt then remove the waterpump pulley (3 bolts) you will see the harness. If you have a workshop manual refer to page 3-3-10. Add a little coolant on the o-ring when installing the new one.
A note on this part - it is an extremely common part used on nearly a hundred Ford, Daimler, Jaguar, Land Rover and Mazda vehicles. Not sure why Aston parts dealers sell it for $240 - it's typical cost is about $12.
Replacing CTS Aston Martin Vantage V8 4.3
I wouldn't buy the foam but I might cut new sections from a new piece. - it's more of a cushion than anything else.
Here's a link to the workshop manual
Aston Martin Vantage V8 Workshop Manual
So everything was put back together and seem to work fine.
The BTM module needed longer wire to connect to the orignal harness but the module seems identical.
Thanks everyone for your help.
I just ordered the new version of this Ford based fan controller to see if it's feasible to swap into my Aston. It was only $22 USD.
Fan Control Module for Land Rover, Volvo, Ford & Jaguar
