Key Fob Programming
Old 01-15-2022 | 11:16 PM
Kamrooz Karimi's Avatar
Kamrooz Karimi is infamous around these parts
Originally Posted by Ashman_E
If you're using the iOS version of the ThinkDiag software, then I never did get this to work on my car.
However, when I switched to Android, it worked just fine.
My car is a '09 V8V, and I successfully programmed a new crystal key with codes using the ThinkDiag for the "Fob" portion and two existing keys for the "Key" portion.
Thanks to let me know I will try tomorrow Android version
Old 01-16-2022 | 04:13 PM
Hey Ashman-E
Android version work perfectly I register my key one first try
Old 01-17-2022 | 12:59 AM
a102768's Avatar
a102768 is infamous around these parts
So the ThinkDiag should be able to add keys for a 2011 Virage?
Old 01-17-2022 | 05:04 PM
yes if you buy key with
ID FOB
FOB SEEDS
you can able register with THINKDIAG
Old 01-18-2022 | 04:40 PM
a102768's Avatar
Thanks very much for confirming that.
It looks like a Volvo fob is the way to go then but can anyone please confirm what the part number is for the 433MHz unit and also a good source for one?
Old 01-18-2022 | 05:36 PM
No problem 👌
United state 315 MHz
Cristal one was on eBay 800 to 1200 make sure buy with both code
plastick less
dealer have but asking more
Old 01-18-2022 | 06:11 PM
a102768's Avatar
Thanks. My car is UK spec so 433MHz but the only Volvo fob part number I have found on this forum so far is for the 315 MHz.
My Virage came with two Crystal keys. Both start the car but only one works on the doors so I want to replace the circuit board and add the new one to the car as I don't have the codes for it. A Volvo key seems like the cheapest way to achieve that
Old 01-19-2022 | 01:05 AM
chrzesm's Avatar
chrzesm is infamous around these parts
You need Volvo 30772194 key. Good luck!
Old 01-19-2022 | 01:06 AM
chrzesm's Avatar
And a good source from Germany: https://www.wikingerparts.de/en/shop...ntrol-30772194
Best!
Old 01-19-2022 | 03:41 PM
a102768's Avatar
Thanks guys, that is really helpful.
Old 02-13-2022 | 05:45 PM
a102768's Avatar
My fob from Wikingerparts turned up this morning but I have just noticed that the 8 digit code on the fob differs slightly from the code on the sticker. One is 30772189 and the other is 30772194.
Is that normal or has the wrong fob ended up in the box?
Update:
Wikingerparts have confirmed that is is all good. Panic over! Just got to wait for my Thinkdiag to arrive and I am good to go.
Old 04-10-2022 | 07:41 AM
Hello all !
after register new key fob (Crystal) with ThinkDiag ,Android
old key not open the door but can start the car
new key not able to start the car but all button work
any idea ?
Old 04-10-2022 | 08:40 AM
Captain Cove's Avatar
Captain Cove is infamous around these parts
Starting the car is from the “pill” inside the key, the only non dealer way to program a new pill into the car is the Ford 2 keys procedure (need 2 different working keys pills to start program a 3rd one). You can move the pill form one key body to a different key body but tricky.
The open doors function is from the code programming with ThinkDiag. Both aspects need to be done when programming a new key so you get both start and doors.
did you scan how many keys you have before starting? Did you identify what working key are mapped to what location in ThinkDiag (1-6 I think)? Did you erase a key? Did you program the new key over an existing key location or an empty one?
Old 04-10-2022 | 10:17 AM
Thank you for your time
all slot was full and I checked only one is registered to the old key and I delete 3 of them and add one !
When new key on have this error
Old 04-10-2022 | 04:07 PM
Import's Avatar
Import has a spectacular aura aboutImport has a spectacular aura about
Just bought a key and fob from Phoenix..steve was great to deal with,.is due tomorrow…
Quick Reply: Key Fob Programming
