14 Vanquish Battery
Old 04-04-2020 | 04:35 PM
RBWIII's Avatar
RBWIII is infamous around these parts
14 Vanquish Battery
Need to replace the battery in a 14 Vanquish 2+0.
I accessed the battery compartment and additional panels will
need to be removed to pull the battery out.
What panels need to be removed, and how are they removed.
thanks
Old 04-05-2020 | 02:46 PM
RBWIII's Avatar
Well that was a chore. Took about an hour and a half or so, probably quicker if I had to do it again. My 15 V12 Vantage was way easier, that took 10 mins. These are the panels that will need to be removed in order to access the battery and remove it without doing any sort of damage to the interior or electrics. Panels were either velcro or screws. I wonder if this would of been easier if it was a 2+2....
Old 04-08-2020 | 09:36 PM
skeena river rove's Avatar
skeena river rove is infamous around these parts
thanks for the write up. How do you like the Vanquish? thinking in trading in my db9 for a Vanq.
Old 04-10-2020 | 01:13 PM
Irish07@VelocityAP's Avatar
I only remove the 2 parts on top left of your parts pic. The L shaped trim and metal surround don't need to be removed. The battery is held in place by that black U-shaped bracket at back of battery; remove the 2 bolts on that U-bracket and slide that bracket upwards, battery will then come out.
Technical Director
Christopher Edgett
214 Maple Ave.
Oliver, B.C
Canada V0H 1T9
Office: (1)250-485-5126
Email: Tuning@VelocityAP.com
www.velocityap.com
Old 11-06-2021 | 10:20 PM
otis74's Avatar
otis74 is infamous around these partsotis74 is infamous around these parts
Hi, I have a 2014 Vanquish with a dead battery. Today I tried removing the seat cushion. It lifts up but I could not pull it out. I was afraid I would damage something by forcing it. Are there clips or screws in the back of the cushion?
Thanks,
Nick
Old 11-06-2021 | 11:01 PM
Thanks,
Nick
Between the lower cushion and the backrest is a rectangular leather trim, pull it out..it’s velcro.
Remove the T30 holding the lower cushion, now you should be able to lift out the lower cushion.
Technical Director
Christopher Edgett
214 Maple Ave.
Oliver, B.C
Canada V0H 1T9
www.velocityap.com
Old 11-06-2021 | 11:24 PM
otis74's Avatar
Hi, thanks for quick response, appreciate the help!
Old 12-15-2021 | 10:37 AM
Esprit's Avatar
Registered PM
Esprit is infamous around these parts
What if anything required resetting or did you use a OBDII power source? I also thought the alarm might go off when you disconnected the battery?
Old 12-15-2021 | 11:02 AM
Seats and windows can be reset by going through the calibration steps in your owners manual..you don't need a scantool for a battery replacement on the +13MY Vanquish.
The alarm will not sounds off unless you arm the vehicle and decide then to remove the battery. Nonetheless, don't lock the doors and you won't have any issues with the alarm activating.
Technical Director
Christopher Edgett
214 Maple Ave.
Oliver, B.C
Canada V0H 1T9
www.velocityap.com
NikitaUCLA
02-18-2020 10:45 AM
Jeff SD
Bentley
07-01-2015 10:38 AM
CMartin348
05-03-2011 10:41 AM
jcramair1
09-22-2003 03:13 PM
Quick Reply: 14 Vanquish Battery
