Replacing Coolant Expansion Tank - Hard?
Hi again everyone. After finally figuring out my misfire issues it seems I have a coolant leak in my reservoir tank, which sits at the top of the engine bay on the left hand driver's side. In order to replace this part, is it a tough fix? Does all of the coolant need to be drained before replacing it? Appreciate any advice before I decide to throw more money at the dealership or tackle this myself.
You can do this...
You will want to drain the tank by siphon or when you remove the hose at the bottom of the tank. There is a connector on the bottom that you will need to disconnect and a couple of bolts. About 20 minutes of effort. @an hour if you are patient and careful!
You can do this...
I replaced the one on my DB9 about a year ago. I had to remove a cross brace covering the tank. I did remove (with a baster) most the coolant in the reservoir. Stuff some old towels under the tank, you will leak some coolant. The top hoses were easy the bottom a little more difficult. Be careful as there is a wired sensor on the bottom that inserts into the bottom of the tank. It's held in place with small plastic (molded) lips. Test your cap to make sure it was not the cause of the leaking. I replaced my cap. Don't rush, the bottom hose can be a bear to remove. Make sure your hoses are in good shape...or replace them if needed. Mine were ok.
Good luck!
Good luck!
Good luck!
Good luck!
Forgot....all the metric bolts were easily removed and replace. Remember to just reverse your removal process as you get things back together. Make sure the clamps are good or replace them. Don't overfill the tank, I filled the tank 1/2 way & after the first use looked at it again and added a little more. Don't overfill!
