V8 vantage killed car when starting with trickle charger attached
Hi
i had my trickle charger attached to the red battery terminal in the engine bay and had the black lead attached to the engine block. I disconnected the trickle charger from power, but still kept the trickle charger attached to the car.
them I had the great idea to start the car with the trickle charger attached. I think it made a brief sound then completely dead. No sound, lights, nothing
any thoughts? Hoping it is a fuse and not a computer. I checked all the fuses in the engine compartment and they looked ok.
attached is a list of fuses from the manual
does the battery reset act like a fuse? Trying to figure out how this switch would trip automatically
The battery reset button is like a circuit breaker .
If you can get in the car then access the battery with a voltmeter and check the voltage . You maybe able to access the trunk through the car and get to the emergency trunk release handle .
My battery reset button is behind the right hand seat. I have noted that I have to hold it in for a few seconds for it to activate. If that doesn't do anything hook up a battery booster to the posts (+/-) under the hood and try to open the trunk lid with the chrome button.
I tried initially to get the trunk panel out from the inside but didn’t see an obvious way to do that
Have you actually checked or verified a known good healthy battery? A bad cell would describe your issue and a battery conditioner plugged in for months would not fix it. Battery reset on the panel behind the passenger seat is only on 2006. 2007 on is via ignition switched input. If I was closer to LA I would gladly help you out.
To OP. That makes no sense to me. As you described, you disconnected the power to your charger/ monitor and just left the hook ups to + and - , correct? On my Porsche, i have the Ctek charger wires permanently attached to + battery and - to body bolt. That way i just connect when car is not used for any period of time. Never had an issue leaving the wires attached. Lots of folks leave the monitor charger wires on. Must be something else going on. Did you look at the wires after that they didn’t ground out on something?
John in Norcal
12-15-2015 08:39 AM
