Rebuilding V8V from accident, ASM and low-speed CAN help needed
Old 08-30-2021 | 11:27 AM
Tashakes's Avatar
Tashakes is infamous around these parts
Originally Posted by acole
UPDATE: SUCCESS!
The only thing left to chase down is to figure out why the infotainment screen isn't popping up. It's attempted to pop up maybe twice in the entire time I've had the car, so I'll take any leads on why that may be, but I'm guessing it'll be a similar process to diagnose.
Great news.
The fuses for the radio, entertainment, etc are under the passenger floor, take a look at those fuses. When I installed my coil overs, I moved the radio module a little and lost radio because it blew a 5A fuse, even though the display was turning on, just the radio would not work. Looks like this cars are very finicky when it comes to shorting out. There are more separate fuses than I have ever seen for many different things, so you will need to check quite a few of them.
Old 11-07-2021 | 06:41 PM
Art G's Avatar
Art G is infamous around these parts
Looking good! Where is it at now and what is left? When do you recon you will be done?
Art
Old 11-07-2021 | 09:15 PM
acole's Avatar
acole is infamous around these parts
Art
All that's left right now is to fix the passenger air bag, the module under the seat went bad and still needs to be replaced. I've got one on order from astonmartinbits so that should be sorted soon. Other than that, it's just bodywork left. Once I get some pictures uploaded, I'll give a proper update.
ipassgas
12-29-2021 07:42 AM
Puddlian
08-16-2020 04:45 PM
Automobilist
12-07-2018 12:34 PM
beyondmars2020
01-25-2015 09:00 AM
Quick Reply: Rebuilding V8V from accident, ASM and low-speed CAN help needed
