4.7 engine ping
Here's the link to my new YouTube (interesting process) video of a irregular background tick that sounds like a pebble hitting a window. 4.7 with 39K miles.. recent oil/filter, upstream O2 sensors, and throttle body replacement. No CEL or Foxwell codes. Not apparent on start-up but after car has idled for a few minutes.
Vacuum leak, mis-fire, plugs&coil time???
4.7 is a noisy engine to begin with vs the 4.3 engine. Sometimes a fresh oil change does 2 things. 1 makes you pay attention to little things 2 increased power and driving skills. Personally I would not worry about it unless you have other issues arise.
-JW
-JW
i hear it, and if what i'm hearing is what you're hearing it doesn't sound like it is consistent or tied directly to the RPM like a rod knock or lifter would be. i'd be wanting to look into it and hope it involves an accessory. sounds like a loose bit of metal being thrown up against the crankcase or a cover plate. maybe a ball bearing or nut?
I have the same noise in my car, it's described in this thread:
V8 Vantage intermittent engine noise - 6SpeedOnline - Porsche Forum and Luxury Car Resource
I am inclined to think that it is a therman insulator rattling, or something of those sorts.
I have also found another video in youtube where another owner of a Vantage has the same noise:
(It seems that I can not find it now)
Hmm...vvt housing and cam phaser. Good thing I have some spare time on my hands. Many thanks for the input from all. I’ll update as I find out more (that 4.3 video sounded identical).
And this is the video I meant before.
It makes the intermittent ticking noise (at the beginning of the video) and also the clutch noise, my car has both:
V8 vantage clutch noise - YouTube
Calling Stuart... you in here, bro? Got any discounts on tuning?
“Calling Stuart”.....got this yesterday.
It’s that time of year again! We only have one Sale per year and this is your chance to grab some huge savings before it's too late. Our Black Friday sale runs Monday, November 22nd to Friday, December 10th with great deals throughout the store
Braking Products: 10%
ECU Tuning: 25%
Engine & Drivetrain: 15%
Exhaust: 25%
Springs: 25%
As this is an extremely busy time of year for us, order processing times may be longer than usual, and tuning file turnaround may be longer than the usual 1-2 business days. Due to very high demand we usually sell out of some items every year. If an item you have chosen is not available to ship immediately, our team will be in touch to let you know the estimated ship date once established.
Thank-you for your business and for supporting the team at VelocityAP!
ECU Tuning: 25%
Exhaust: 25%
Springs: 25%
Kalepsis -
I believe what you are hearing/describing towards the rear of your Vantage is called ‘Gear Chatter’. This was discussed my Mike of Bamford Rose and he indicated that it was just the slight difference in gear tolerances that produce this noise. He indicated that it was not an issue and that nothing is wrong.
Also stated by Mike, and backed up by a highly qualified Aston Martin technician I spoke with, if your Aston has gear chatter, then fitting a dual plate clutch and lightweight flywheel will most likely make that chatter more noticeable.
