Has anyone installed the Naviks CarPlay unit for garmin based systems?
#31
The one year warranty is a non-issue for me. Modern electronics don't age. In most cases, they are DOA or they work for a very long time.
Production and engineering team rolled into one sounds like two guys operating out of a garage, which is somehow better than guys operating out of a house? And where do you think most electronics are manufactured these days? It isn't in the US. It is Korea or China.
That said, I have a friend with mechanical and electronic engineering degrees and he has learned to code at the hardware level. He is currently finalizing a military-grade engine, designed from scratch and running his software working out of a small shop with a small team. If Chuck built something in his kitchen for my car, I'd buy it in an instant, but I know the guy and what he can do.
DashLynx needs to get product into the hands of knowledgeable users and build some street cred. Not take swipes at someone that has actual product that works for these niche cars we love. Most Astons either have Volvo nav or Garmin (2011 to ??). The Garmin unit is a GVN54, and Garmin sold variations to many car companies. Learning that system would be a gateway into more than just Astons.
#32
The whole interaction is awkward at best. I was looking into the Naviks system, but Aston Martin themselves now offer a retrofit CarPlay option though the dealership that uses the factory joystick on the radio, rather than an aftermarket one. The OEM part number for the Garmin-based systems is 708971. Book time is 1.5hrs of labor, but an east coast dealer charged a friend 5hrs, so shop around accordingly.
#35
I tried it using CD, Sirius and FM radio. Unfortunately the joystick sends commands to both interfaces simultaneously. The reason it works in aux is that the joystick has no effects there, so you’re just controlling CP. since I use CarPlay for music, phone and navigation, it’s a non-issue for me, but if you listen to CDs, you have a problem.
sirius sounds better through the app anyways and FM is just awful.
This post will no doubt prompt the new guy into another post about how his nonexistent system is better. I have no stake in Naviks. The customer support I got from Naviks was outstanding. It was pretty obvious I was dealing with a small business. He answered his phone all weekend for my silly questions and always had an answer. He was even aware of the different revisions regarding the details of the waterfall.
#36
Navtool has a selection of products from CP/AA to cams-and-mirroring to cams only for the Volvo and Garmin cars (and Made in USA, so Dashlynx won't have that angle to attack). I was interested in their mirroring system, but they "upgraded" the control system to a hideous (IMHO) wireless remote. I assume they use that remote for the CP/AA units.
I updated the maps on our Garmin this week, so I may settle for adding front and rear cameras. We don't commute or run errands in our Vantage, so quickly/easily being able to select a new nav destination isn't as important for us.
I'm almost certain that the Sirius stream is the same as the satellite signal. Both are digital. If Sirius sounds better through Naviks, the Naviks analog conversion must be better than what Aston or B&O selected. That surprises me. A lot!
Thanks for testing. I came back to the thread just to see if you had posted results, but I will turn off notification again.
#37
This has gone far enough and way off topic, which was a discussion of Naviks. Members please start another thread regarding Naviks and Dashlynx stay out of it. I would like to know what dog gretslox has in this game as he only joined to flame Dashlynx. I would ask you both to stay out of any subsequent discussion of Naviks. Thread closed
#38
yes we can and expect the discussion to get back to Naviks. In the meantime both Dashlynx and gretslox are barred from the AM forum while IB investigates this matter. Back to topic please.
#39
Hi,
I just installed Navik CarPlay on my DB9.2, it took me around 9 hours all in but most of that was staring at things trying to make a decision! Taking the dash and console apart was straight forward, the only trouble i had was fitting everything under the woofer housing/ rear seat. all back together and working perfectly, a very nice upgrade and certainly doable for the amateur. The video on this thread is also a good help so thanks for that. Navik comms was excellent and i am UK based.
#41
@Teekster It's been few months since you installed naviks unit, any issues? Did you end up installing front park camera? I'm thinking to go with Naviks for my 2013 Vantage, I'm assuming it's gonna be same as your car.
+ good support from Naviks
+ supports front and rear camera. When you switch reverse to drive, turn on front camera for few seconds. You can also switch on front camera manually
+ installation is plug and play
+ no visible external parts (control with a radio unit switches/joystick)
- main unit with antenna must be in a cool place (behind the radio) - if not, it is overheating and hangs up
- system response is so so
- audio quality - because output is analog and before analog to digital conversion cables get some noise.
- some echo during phone calls (on the other side)
#42
hello, are you sur it's a real OEM retrofit and not the IDCORE material ? can you ask them if they can add 2 cameras and not only one ? thanks ;-)
#43
#44
My Aston dealer just confirmed me IDCORE made the kit for aston ;-)
#45
Well, I finally got around to installing a front camera. I didn’t make a video, as there is already an excellent video on YouTube by aston1936. I am jealous of all the extra space in front of the radiator on a DB9. The V12S is much more tightly packed, requiring removal of the front under tray to get access to the lower grille area. I also pulled the brake ducts off. My camera came with an RCA cable and power plug that don’t fit through the holes in the grille, so I tucked them over it (this is where removing the brake ducts comes in handy). I suggest sourcing one like he has in the video with a lower profile plug.
