Aftermarket Brake Pads and Rotors V8 Vantage
2006 V8 Vantage ... 20,500 miles, all stock, 3 pedal.
No track use or plans for track use.
I need to replace pads (@3mm) ... Considering rotors also but the thickness checks okay for now.
Many non-OEM pads to choose from. I saw Brembo, Pagid, Hella and others.
What success / suggestions / warnings have you had with non OEM pads and rotors?
Thanks ....
Thanks ....
I have Porterfield RS-4 pads on original rotors... have about 31k miles. No squeal, good grip, long wearing so far, virtually dustless ... don't get track pads.
I also had Porterfield R4-S pads on mine. I replaced the rotors, hub bearings, and pads all at once. To be honest, I didn't see any reduction in dust from the old pads. And they still squealed, especially at low speeds coming to a stop. I could never get the right rear corner to quiet down. But the braking performance was excellent. Others have had better experience with them.
There is significantly reduced grip over the factory Pagid pads, but the dust is so extreme with the Pagid, for the street they're fine.
![](https://cimg7.ibsrv.net/gimg/www.6speedonline.com-vbulletin/2000x901/screenshot_20230916_065048_sheets_1eca8e43771d8aac1c25cffb5a6ea8cd8657cf9f.jpg)
I attached a screenshot of the part numbers, prices paid, and source for when I replaced my brakes last Fall. I've been very happy with all of it.
Thanks ....
Thanks ....
timwhayden
01-24-2013 09:45 PM
