Ebrake Stuck engaged on my 09 Vantage!
Are there any good fixes to un stick & lubricate the Ebrake or cable or wheel to help my Ebrake not get stuck.. I have less than 15knon my car.
Larry
Larry
Is it physically stuck or might your issue be the sensor/warning light? I think it is somewhat common for the e-brake switch within the handle mechanism to foul up, e.g. leather trim cover interfering.
Update on Ebrake
Thanks for your replies!
If I lift it up w 2 hands as high as possible, I found it releases & the light turned off!
It took multiple attempts..
How to adjust it? Or lube it to allow the cable or lock to release easier?
