08 V8V Door Module Failure
Old 09-05-2024, 03:59 PM
thom_77's Avatar
thom_77
Hi everyone -- Just had my driver's door module fail; the window no longer operates, or at best operates intermittently. I tried pulling the fuses in the floor box, no dice. So it looks like it's the module.
Just got a quote from both a dealer and from my indy specialist of approximately $4,000 to replace both modules. They need to now be replaced in pairs due to updated modules having been introduced and the old modules won't function with the newer ones. New modules are $1000/each, plus about six hours of labor plus computer reflashing to accommodate the upgraded units. Needless to say, this is insane. I've had my share of big repair bills, but fixing a power window for $4k is madness.
So my question is, if I source a used module from the same year and replace it, will it function properly or will it need to be coded to the car? I can find these on ebay for $200 all day long. I just want to make sure it's not more complicated than a swap.
Old 09-05-2024, 06:44 PM
J doubleU's Avatar
6 hours of labor? They are correct that new modules need programmed and you need the car configuration changed also. Labor should be half of that.
Buy a module used and make sure it's the correct side as they are D or P and should be marked on the label. Plug it in and learn the window.
JW
Old 09-05-2024, 08:02 PM
thom_77's Avatar
thom_77
Thanks, yeah I noticed that they're D or P so that's easy enough.
Labor did seem high; I had read that it should be three hours for the whole job but the service tech said it's 3 hours per door. Regardless, the whole endeavor seemed way too costly for what it was, saving three hours of labor isn't a dealbreaker either way.
I'm going to order a used unit and have it installed with my interior guy. Should be fine.
Old 09-06-2024, 08:28 PM
mrtzmd's Avatar
mrtzmd is infamous around these parts
Great info thank you. I'm dreading this repair. Would you please let us know how it goes with installing the used ones?
TIA
Old 09-06-2024, 09:02 PM
thom_77's Avatar
thom_77
Will do. I'm scheduled to have it installed on the 18th of September so I'll report back here how it went.
After this, I'm going to enquire with a few of the big electronics rebuilders like Programa and Remanx and SIA about a refurbishment programme for future reference. There has to be a better option than simply hoping to either find a good used one, or spending several thousand dollars to overhaul the entire system for what should be a simple repair.
Old 09-06-2024, 09:17 PM
mrtzmd's Avatar
Thank you Thom_77, I agree makes no sense! Good luck!
Old 09-08-2024, 12:41 PM
AUVDRSN's Avatar
AUVDRSN is infamous around these parts
Don't jump to the module!
I'm dealing with the same issue with my Rapide. The problem is almost certainly with a broken wire in the door harness, almost certainly the ground wire.. get an VOM and check continuity from the harness connector to the module connector buried beneath the door card..
Old 09-08-2024, 09:40 PM
thom_77's Avatar
thom_77
If it were a wiring issue, would it not affect all the door functions... window, locks, mirror, etc? Only my windows are malfunctioning, all the other door functions work.
I was under the impression that if only one thing died, like the windows, it was likely to be a bad module itself.
Old 09-09-2024, 12:09 AM
AUVDRSN's Avatar
That is true, if indeed you have a broken ground to the module, it will be dead in terms of the mirrors, but not necessarily the locking.
Tahoe M3
07-03-2024 09:59 PM
sonies
03-16-2020 04:49 PM
Oliver Goldsmith
11-02-2017 04:20 AM
oo7
05-25-2013 05:53 PM
SeattleBum
04-18-2013 10:47 AM
Quick Reply: 08 V8V Door Module Failure
