Rubber pads under the slam panel
FYI, noticed 1/2 the rubber pads were missing last time I took off the panel.
For reference, they are 3M SJ-5003 . Typically sold in Qtys of thousands but available on eBay in smaller strips.
The ones on my car were grey (or white that got dirty with time). After a good cleaning for adhesion I replaced them all with black ones since that's what was quickest to get.
Hi @UltraMarine where exactly is this? I’m embarrassed to say I don’t know what a “slam panel” refers to!
Alright, you all made me paranoid, so I went and removed the panel to take pictures! The slam panel is the radiator cover panel:
And underneath the front lip of the slam panel is where the rubber pads are on my car so the metal lip of the panel doesn't rub into the grille:
Thanks, I need to take a look!
How come many of your bolt heads on top of the slam panel look smooth too? Do you have little covers on those? Mine all look like the bolt heads you have on the sides (with the Torx part exposed).
Good observation!
There used to be some of the torx bolt heads covered, and I figure the service guy was just not replacing them as I had fewer and fewer over time.
The parts catalog seems to indicate that each bolt head should be covered, seen by part A & J on the diagram:
Aston Martin lists the part as "CD33-A15K610-AA Torx Cap, TX30, OD 16.2mm" , and they sell for $0.50ea at your favorite online car part seller.
I looked into it, and it looks like there's only 1 company I can find that makes them. They are in France and sell through eBay USA.
https://www.ebay.com/itm/124490902174?var=425361765503
By the above spec, they are Black, T30, 1", and a perfect fit. Bought a bag of 20
porschespeeddemon
09-06-2010 07:18 AM
