AMR clutch life…..
Old 09-10-2024, 04:02 PM
Argus's Avatar
Argus has a spectacular aura aboutArgus has a spectacular aura about
AMR clutch life…..
How long should an AMR duel plate clutch last?
Old 09-10-2024, 06:28 PM
volvodrummer's Avatar
volvodrummer is infamous around these parts
In what car with what transmission?
Old 09-11-2024, 08:29 AM
Argus's Avatar
Manual
Old 09-11-2024, 09:37 AM
So an VH manual car V8/ V12 or an AM6 7sp car from 2020/21 ?
I’ve heard things about the newer cars and clutch problems from internal people.
Old 09-11-2024, 10:29 AM
Argus's Avatar
2007 v8 manual. But since you seem to have inside information do know which radio module is the AM band? My AM band is dead and I was going to have it repaired. Also once I remove the correct module from the system will it think it has been stolen and not be fixable?
Old 09-11-2024, 10:51 AM
Right on. It’s my understanding that the twin plate clutch was supposed to improve longevity by a decent margin over the stock unit from ‘07, but as wear items go results may vary. Fun to my head I’d say it should be good for at least 30k miles ?
As for your radio, again I may not be the one to ask but IIRC, it’s the same system/architecture as the Volvo XC90 system from that period. Modules connected by a fiber optic loop, so unlikely to work if you remove a component. Your AM band unit may be VIN coded to your car thus unable to operate with a donor/used unit. I’d guess that repairing your original should be fine if possible.
Old 09-11-2024, 11:39 AM
Marmot's Avatar
Marmot
I believe that there is a long ago TSB regarding the AM band failures in the 07 era Vantages. You might want to ask the dealer. I can't seem to find it right now unfortunately.
Old 09-11-2024, 02:51 PM
MRCW's Avatar
Do you still use AM? as a back up there are a couple of BT streaming apps that you can access some AM stations
BMW-North
03-30-2024 07:09 AM
Terminator
09-07-2016 02:26 PM
kurtis_h
10-23-2013 11:02 AM
edelectra
10-19-2009 09:48 AM
Quick Reply: AMR clutch life…..
