Service light reset - 2nd-gen Vanquish
Old Yesterday | 07:38 AM
Kalepsis's Avatar
Kalepsis is a name known to allKalepsis is a name known to allKalepsis is a name known to allKalepsis is a name known to allKalepsis is a name known to allKalepsis is a name known to all
I recently changed my oil in my 2015 Vanquish and needed to figure out how to reset the service light. The Foxwell NT510/530 does NOT work for these cars, and Autel doesn't have any scanners that are compatible with it, either (I emailed the company directly). So frustrating. After a few weeks of searching I came across a video on YouTube where a guy resets the light on a 2014 Vanquish without a scanner, but there are a few details I need to make clear. Here is the process:
1. Enter car, leaving the driver's door open. If you close the door, this won't work.
2. With key in position 1 (in the dash but sticking out about 3/4 inch), press and hold the t1/t2 button on the left side of the gauge cluster.
3. Push key to position 2 (flush with dash) while still holding the t1/t2 button. Do not push it all the way in to the start position.
4. Watch for the yellow triangle in the tachometer area to flash three times, then release the t1/t2 button. You should see an immediate quick flash of the triangle and hear a ding.
5. Cycle power. Service light should now be out after system check.
I know this will work for 2014-2018 Vanquishes. Probably also V12 Vantages and Rapides with the AM29. It might work for other, late-2010's VH cars, but I'm not sure.
Hope this helps other folks who do the servicing on their supercars themselves.
Old Yesterday | 08:28 AM
J doubleU's Avatar
Volvo cars, all the same on VH Gaydon built cars.
Old Today | 04:13 AM
ram_g's Avatar
ram_g
Did you try connecting your scanner to the body port (on the passenger side, at least on US cars) to reset the service reminder? I have an Autel MP808 and was able to reset the light on my 2015 DB9 after I figured out that I needed to use the body port and not the OBD port. Until that point I was getting super frustrated.
carifin
Bentley
17
10-11-2020 05:56 PM
Duane
07-08-2020 01:49 PM
atp160
Cayenne 955/957
07-28-2011 12:43 PM
SoCal955
Cayenne 955/957
24
10-26-2010 04:49 PM
sbest
05-25-2010 02:17 PM
Quick Reply: Service light reset - 2nd-gen Vanquish
