Audi Vendor Classifieds vendor classified area...do not post here unless you are a forum sponsor
Audi Air Lift Performance Now At GMP Performance
Old 06-03-2016 | 11:02 AM
GMP Performance's Avatar
Site Sponsor
GMP Performance has just ventured into a new branch of the performance suspension world and our excitement is palpable here at the shop. You could almost say, we're...floating on air...
Too cheesy? Yeah, we know, sorry about that. But we really are very excited to share this with you. GMP has joined forces with the awesome people at Air Lift Performance to start offering kits and installation here at the shop.
A Little About Air Lift Performance
Adjustable!
Drive it. Show it. Track it.™
No other suspension gives you the ability to comfortably drive you car daily, slam it to the ground for show-winning stance, or tear up your favorite race track: all with the touch of a button and twist of a ****.
0-125 PSI
Up to 5 inches of drop
MOST KITS REQUIRE NO MODIFICATIONS FOR INSTALLATION
BOLT-ON OEM REPLACEMENTS
Every upper and lower mount is designed to ensure an exact fit to your vehicle. Kits always include tabs and brackets for brake lines and ABS wiring, just like OEM.
Since each kit is custom made for a particular chassis and painstakingly tested, you can be confident that it's got what it takes to take your ride to the next level.
MONOTUBE SHOCK INTERNALS
MOST KITS OFFER UP TO 3" OF THREADED ADJUSTABILITY
Set the strut/shock to your desired length to give you additional lift if you want more ground clearance or that perfect slammed position. This flexibility allows you to tune the suspension to match your needs without giving up precious stroke.
  • Runs Cooler
  • More Sensitive
  • Weighs Less
  • Precision ground and triple chrome plated piston rod provides long life and reduces friction.
  • All weather shock proof
  • Floating divider piston keeps Nitrogen gas charge isolated from shock oil to prevent cavitation and loss of performance.
  • High pressure Nitrogen gas.
30 LEVELS OF AWESOME
EASILY TUNE DAMPERS WITH 30 LEVELS OF ADJUSTMENT.
With Air Lift’s large range of available damping, you can always find a setting to suit your needs. Like it soft and comfortable for boulevard cruising or stiff for ultimate response and roll control at the track? We have you covered.
Damper adjustment extenders included with select kits for vehicles with hard to reach shocks/struts.
PRECISION ALIGNMENT
UP TO 3° OF NEGATIVE CAMBER ADJUSTMENT
*Available on select kits. Degree of camber adjustment varies per kit.
HIGH PERFORMANCE MONOBALL UPPER MOUNTS
Maintain the best tire contact patch on the road as possible. Our adjustable camber plates not only help you achieve a show winning stance, but also help you dial in the optimum geometry for maximum chassis performance.
VITAL HARDWARE
WHEN THE APPLICATION CALLS FOR CUSTOM OR SPECIALIZED HARDWARE, WE INCLUDE IT IN THE KIT TO ENSURE THE BEST FIT, THE HIGHEST PERFORMANCE, AND THE LOWEST RIDE.
WARRANTY
ONE YEAR LIMITED WARRANTY
We know stuff happens. Isn’t it good to know that Air Lift Performance will cover every part in your kit for one year and do it with a smile?
Kits Available
Audi 8P A3/MK2 TT
Front /// Rear
Audi MK3 A3/TT-S
Front /// Rear
Audi MK2 TT-RS/S3/RS3
Front /// Rear
Audi B8 A4/A5/S4/S5
Front /// Rear
Audi B6/B7 A4/S4/RS4
Front /// Rear
Audi B5 A4/S4/RS4
Front /// Rear
Audi A6/S6/RS6/allroad
Front /// Rear
Air Management
3H System
  • Controller
    Both systems come with the Air Lift Performance 3 controller, a device that is truly amazing to hold and to use.
  • Free Mobile App
    Take full control of your 3H/3P system with a FREE mobile app with no additional hardware needed, for all compatible devices.
  • Fully Integrated Manifold
    By combining the ECU, pressure manifold, and Bluetooth module into one compact unit, the new manifold takes up less space than multiple components.
  • 5 Custom Presets
    The system quickly adjusts to and maintains height and/or pressure presets with the push of a button.
  • Height + Pressure
    The system comes with everything needed for height and pressure control up front, for the best value. Start driving in pressure mode and install height sensors later, without the need to purchase an upgrade.
  • Height Sensing Technology
    Height sensors give the system the ability to automatically adapt to changes in vehicle load.
  • Anti-Cross Loading + Axle Equalization
    With the combination of pressure and height sensing technology combined, 3H can achieve the correct height without radical differences in pressure.
  • Show Mode
    Turn your vehicle off and continue to control your air management via the controller or FREE mobile app.
  • Rise on Start
    Turn the key and the system will take you right to your programmed ride height.
  • Easy Install
    The key components of this system require less drilling, wiring, and take up less space than other air management systems for a cleaner install.
3P System
  • Controller
  • Free Mobile App
  • 5 Custom Presets
  • Show Mode
  • Rise on Start
  • Easy Install
INNOVATIVE CONTROL
Take your air game to a whole new level with our intuitive controller, featuring a full color display and rotatable keypad, tailored to your vehicle's setup.
TAP THAT APP
Free. Easy. No additional hardware to buy or install.
System Updates
Updated system software can be sent directly to the manifold and controller via the mobile app!
Bluetooth Powered
Use your compatible mobile device as the controller.
FULLY INTEGRATED MANIFOLD
The ultimate air suspension setup needs the most advanced manifold.
  • High Grade
    No compromise has been made, using the best components and materials in existence.
  • Advanced Processing
    The state-of-the-art 32-bit processor powers advanced height + pressure algorithms for the most precise 4-corner control.
  • Single Harness Connection
    The system comes with a simple and streamlined wiring harness for an easy and clean install.
  • Fully Integrated
    Less components to buy and install with the ECU, manifold, and Bluetooth in one.
  • Built-in Bluetooth
    No antennas, hardware, or additional accessories are needed to connect your mobile device to the manifold.
  • Accelerometer
    The system detects the movement of the vehicle and makes accurate and intelligent adjustments at the right time.
  • Limitless Mounting Options
    The compact design, harness connector location, and rotatable logo plate all allow for limitless placement options.
REACH NEW HEIGHTS
Improved Design
Our engineers focused on creating an improved height sensor arm with an angular design to ensure increased sensor life compared to straight-arm designs.
Height Sensor Compatibility
Connect any existing compatible height sensors to 3P, or easily upgrade with the height upgrade package, and you now have 3H.
Slim Connection
3H height sensor cables have tiny connectors, which mean they have the ability to fit through many existing holes in the vehicle's frame and body. No more drilling large holes!
AUTOPILOT V2 AIR MANAGEMENT
Advanced, digital 4-way air spring control.
ADVANCED AIR MANAGEMENT
AutoPilot V2 is the most advanced pressure-based air suspension control system on the market. Nobody gives you more features or easier installation. Complete kits available with everything you need for a professional installation.
8 USER PRESETS
Program your favorite ride heights and easily adjust suspension dynamics to compensate for additional passengers and cargo. Set one for “all up” one for “all down” and anywhere in between.
SUPER COMPACT MANIFOLD
Our patent pending integrated manifold and ECU assembly makes installation simple with OEM quality wiring harness and only 3 wires to hookup to your electrical system: power, ground and ignition. Features large 6mm valves, integrated pressure sensors, and available with 1/4″ & 3/8″ line configurations.
ANY COMPRESSOR OR TANK
AutoPilot V2 can be purchased with any of our air tanks in aluminum or steel. We also offer compressor upgrades and dual compressor options. Have a tank and compressor already? Then opt for one of our “no tank/no compressor” kits.
EASILY EXPAND
Add an additional compressor for faster tank fill time and even greater reliability. Just use our second compressor integration harness and a compressor of your choice.
We were so anxious to get this limbo party started that we got an install in as soon as we could. Teaming an Air Lift kit with Velos Designwerk's D5 Directional wheel on a beauty of a blue S5 Cabrio, it made for a stunning combination indeed! This Audi is now ready for its #LifeOnAir. Will you be next?
