Audi B9 A4 2.0T AWE Tuning ColdFront Intercooler System - GMP Performance
Cool to the core. Presenting the AWE Tuning Audi B9 A4 2.0T ColdFront™ Intercooler!
The AWE Audi B9 A4 2.0T ColdFront™ Intercooler
Multiple phases of design have resulted in AWE’s efficient cooling solution. Cast aluminum end tanks with internal baffling and bar/plate aluminum core for maximum heat transfer, manufactured to handle even the harshest amount of boost pressure.
Whether you are simply running enhanced software or are planning on a larger turbo upgrade, our ColdFront Intercooler solves heat related issues that come with more boost. Keeping your intake air temperatures low and pressure drop at a minimum results in better engine output, especially when outside temperatures climb. The ColdFront™ will provide the safety margin needed in order for you to push the limit with confidence.
What’s in the box?
Complete AWE Tuning B9 A4 2.0T ColdFront™ Intercooler assembly, support bracked, and all required installation hardware.
Note: the ColdFront™ Intercooler reuses the factory intercooler hoses and clamps.
Note: the AWE Tuning B9 2.0T ColdFront™ Intercooler is for racing use only.
Now for what you really want to see: performance specs!
AWE Tuning B9 A4 2.0T ColdFront™ Intercooler Dyno Test
To find out more, click here or message us with any questions!
- Average cooling efficiency of 92% over stock
- Fits securely behind stock crash bar
- All aluminum construction for maximum heat transfer
- Efficient bar and plate core construction
- Cast aluminum end tanks with integrated internal baffling
- CAD designed and CFD tested to ensure optimized flow in and out of core
- Pressure tested assembly before leaving our facility
- No effect on OE radiator or A/C systems
- Utilizes factory hoses and clamps
- Designed and manufactured in-house at AWE Tuning
- No Check Engine - Guaranteed
- Perfect fitment - Guaranteed
What’s in the box?
