2004 Nissan 350z Road Race Car - Piper Cage - Over $67k Inv - Never Seen the Track
Year: 2004
Make: Nissan
Model: 350Z
Price: $27995
Mileage: 72211
Color: Blue
Location (State): KY
Transmission: Manual
Drivetrain: Rear Wheel Drive
Suspension improvements include KW Club sport coilovers, SPL v3 front upper control arms, SPL v5 front outer and inner tie rods, SPL rear toe links, mid links, and camber links.
Braking is handled by a Brembo, custom painted, 14" 6 piston front and 13.6" 4 piston rear slotted big brake kit and upgraded Carbotech pads. Volk TE37 18x10.5" Flat Black Wheels wrapped in Toyo R888 tires and Rays black short lug nuts sit on all four corners.
Aerodynamics include an authentic Nismo v2 front bumper, APR heavy duty front splitter with 6 secure points, Seibon +10mm wider carbon fiber front fenders and the world record setting Aeromotions R2.Two Active Spoiler. I have also added the 2007-08 Nissan OEM hood and Aerocatch hood pins to secure the hood at any speeds.
Performance has remained fairly simple to keep the vehicle legal. These improvements include a Haltech Plug and Play Engine Management System, Haltech dual wideband, one sensor on each bank, and dual gauge to keep an eye on air fuel ratios. A motordyne plenum spacer, XERD long tube headers, and the Greddy Ti-C exhaust finish it out.
The driveline has been strengthened with a Quaife Limited Slip Differential (LSD), Injected Performance rear differential brace, ACT Streetlite flywheel, and Exedy stage 1 pressure plate and disc. I have also installed the Nismo adjustable short shifter to help with quicker shifts around the track.
Cooling modifications include a custom 82mm, extra large radiator with aluminum fan shroud and electric fans, Nismo finned differential cover, custom engine and differential oil coolers with temperature sensor, and engine coolant bypass to help coolant flow to the rear cylinders.
Interior and Safety has been upgraded with a Piper Motorsports safety cage (known as one of the best if not the best cage builders on the east coast), Recaro XL racing seats with adjustable driver sliders, window net, ATL fuel cell with containment cover, Safecraft fire extinguishing system with pull handle, and remote battery kill switch. A Sparco Suede Racing Steering wheel and quick release system has also been installed.
The 2004 Nissan 350Z has been upgraded with future engine performance modifications in mind. The ATL fuel cell houses a custom 3 fuel pump slosh box (currently only one pump is active), custom 3 to 1 aluminum y-block, and larger fuel lines going up to the Injected Performance fuel rails. Deatschwerks 1000cc injectors are also currently running flawlessly on this engine.
The Nissan 350Z was finished off with a custom Lamborghini LP640 matte blue paint job, this IS NOT a wrap, and fully painted cage and interior.
An opportunity has come up that I cannot pass up so our loss is your gain. If you have any questions please don't hesitate to email me at gbaker@iglou.com.
List of Modifications Include:
Suspension:
KW Club Sport Coilover Kit
SPL Front Upper Arms (v3)
SPL Front Outer Tie Rod ends (v5)
SPL Rear Mid Links (v2)
SPL Rear Toe Links
SPL Rear Camber Links
SPL Inner Tie Rods
Professionally Corner Balance (3300lbs with 170lb driver)
Braking:
Brembo 14" Slotted 6 Piston BBK - Front
Brembo 13.6" Slotted 4 Piston BBK - Rear
Carbotech Pads
Volk TE37 18x10.5 Flat Black
Toyo R888
Rays Short Black Lug Nuts
Cooling:
Custom Race Radiator 82mm
Custom Aluminum Fan Shroud Upgrade
Nissan Rear Coolant Bypass
Custom Engine Oil Cooler Setup
Nismo Differential Cover
Custom Rear Differential Cooler with Temperature Sensor and Module
Interior and Safety:
Recaro XL Racing Seat x 2
Recaro Side Brackets x 2 (Steel)
ATL Fuel Cell
Piper Motorsports Road Race Cage
Schroth Safety Harness
Safecraft Fire Extinguishing System
Sparco Steering Wheel
Sparco Quick Release Hub
Aerodynamics:
Nismo V2 Front Bumper
APR Front Splitter Custom Nismo
Seibon Front Fenders
Aeromotions R2.Two Wing
Aerocatch Hood Pins
Aerocatch Flush Hood Fastener Kit
Nissan OEM 08' Hood
Driveline:
Quaife LSD
ACT Streetlite Flywheel
Exedy Racing Stage 1
Injected Performance Differential Brace
Nismo Adjustable Short Shifter
Performance:
2006 RevUp VQ35DE Engine with 35k miles
Haltech EMS Mounting Bracket
Haltech Dual Widebands (2 Sensors)
Dual Wideband Gauge
Motordyne Basic Spacer
Deatschwerks 1000cc Fuel Injectors
Triple Fuel Pump Setup (Only 1 Active Currently)
Xerd Long Tube Headers
Greddy Dual TiC Exhaust
Rare JDM Harness Cover
New Nissan OEM RevUp Engine Harness
PorscheEnthusiast
11-13-2015 03:23 PM
AJUSA.com
997 Vendor Classifieds
10-08-2015 06:50 PM
