2007 Porsche 997 Turbo VR825 kit and RED HRE
Year: 2007
Make: Porsche
Model: 911
Price: $85000
Mileage: 23600
Color: Slate Gray
Location (State): FL
Transmission: Manual
Drivetrain: 4WD & AWD
Everyone knows this car dont have to say too much about it.....
Proven Numbers:
- Race Mode the car makes 760awhp at 1.6bar of boost on our Mustang Dyno
- Low Boost Street Mode the car makes 600awhp at 1.2bar of boost on our Mustang Dyno
- Verified 60-130mph Best Time is 6.04 secs.
- Verified TX Mile Top Speed Fastests Stock Motor 997 Turbo is 206.2mph
- Best 1/4mile Trap Speed is 135mph
- Best 0-60mph time of 3.04sec.
Engine/Performance:
- Vivid Racing 825HP Performance Kit
- Custom Aluminum 3inch Y-Pipe Painted Slate Gray with Red Couplers. Features water injection bungs.
- Custom Throttlebody Plenum Pipe with larger 78mm Cayenne TT ThrottleBody
- Converted Porsche oil and water fittings to AN for Garrett turbos
- Garrett GT3076rs Turbochargers with a .63a/r
- Tial 44mm External Wastegates with .8bar spring.
- Agency Power High Flow Bar and Plate Intercoolers Modified with 3inch outlets to 3inch YPipe
- Agency Power Lower Silicone Boost Hoses Red
- Agency Power Fender Mount Cold Air Intakes Retaining OEM MAF Sensors and BOV Recirc Tubes
- Agency Power Twin Adjustable Blow Off Valves set up 50/50
- Agency Power High Flow Performance Headers for Garrett turbos and Tial Wastegates
- JIC Cross 80mm Exhaust System with 100 cell Cats
- Softronic custom ECU Tuning. VTG delete mod, race gas and pump gas map.
- Greddy Profec B Electronic Boost Controller
- AEM Water/Meth Injection Kit
- Nitrous Express Dual Intercooler Spray Kit
Exterior:
- Vorsteiner VRT Carbon Fiber Front Bumper
- Vorsteiner VRT Carbon Fiber Rear Bumper
- Vorsteiner VRT Carbon Fiber Rear Wing
- NR Auto Carbon Mirror Inserts
- [COLOR=black]TechArt Side Skirts[/COLOR
- Porsche OEM Clear Side Markers
- Front End has 3M clear bra under wrap
Suspension:
- KW V3 Adjustable Coilovers
- Agency Power Front Adjustable 27mm Sway Bar
- Agency Power Rear Adjustable 24mm Sway Bar
- Agency Power Front Adjustable Sway Bar Links
- Agency Power Rear Adjustable Control Arms
- Corner Balanced and Aligned - GT2 Specs
- HRE C93 Competition Racing Wheels 19x8.5 and 19x11 Flat Black Center/Gloss Black Lip. Front weight of 19lbs rear of 20.5lbs. These wheels will go with the car if you buy at 90K
- HRE P40SC Brush Red Nitto Tires 20x13 Rear and 20x19 front ( 345 /245 )
Brakes:
- Brembo 2pc Floating Slotted Rotors Front - 4lbs lighter then stock
- Brembo 2pc Floating Slotted Rotors Rear - 3lbs lighter then stock
- Endless Racing Brake Fluid
- Agency Power Short Throw Shifter Kit
- Agency Power Precision Shift Linkage
- Clutch Masters Stage 3 Full Disk Clutch Kit
- Agency Power Bolt-in Performance Roll Bar with harness and diagonal bar painted Red color of the stock HRE C93
- Red Seat Belts
- Carbon Trim Shift ****, Brake Lever, Cup Holder Trim
- Slate Gray Center Console
- Laser Jammers by Blinder
- Custom switches for NX and AEM Kit in Ash Tray
- DCT Custom Flat Bottom Steering Wheel with carbon fiber, preforated leather, and suede
- Renline Pedals
- Alcantera shifter and center arm rest cover.
New Techart LED lights costume done to fit VRT Bumper!
Just had oil changed . Car is hardly used since i moved to FLORIDA….
I can be reached on my cell 201-658-2004 or via email mcjoe691@aol.com had someone comment on the front fenders they are wrapped in clear film with the hood also.
I am looking into buying some houses in Florida with my old man to flip. Need some cash on hand!!! didnt want to do this but this will bring in more money to buy something more CRAZY!!! I will miss her greatly !!! she is a GEM
bump and GLWS!
