1997 Viper GTS Twin Turbo (1192 rwhp at 15 lbs)
Year: 1997
Make: Dodge
Model: Viper
Price: $72000
Mileage: 22581
Color: Blue with white stripes
Location (State): NV
Transmission: Manual
Drivetrain: Rear Wheel Drive
Built by JBE Racing, car made 1192 rear wheel hp at 15psi on 50/50 mix of 93 octane and C16.
ENGINE
Dual 70mm throttle bodies
JM Striker cylinder heads
Shaft mounted rockers
Diamond forged pistons
Eagle H beam rods
Billet main caps
Clevite race bearings
Cometic head gaskets
ARP main and head studs
Anti-bleed down roller lifters
Chromoly pushrods
Custom polyurethane engine mounts
Custom ported aluminum intake manifolds
Triple pass aluminum radiator
TURBO / EXHAUST
Precision 76 mm Turbos
Tial 44mm waste gate
Tial blow off valves
.131 thick stainless turbo headers (all hot parts were Swain coated)
3.5" stainless air inlet tubes to front mounted air filters
3" stainless downpipes
3" Corsa stainless exhaust system
PCM / FUEL
Autronic SM4 EFI
Custom crank trigger
96 lb. injectors
M&W CDI Ignition
LEP billet hanger with 3 fuel pumps in custom baffle
TRANSMISSION / REAREND
Fully built G-FORCE T56 with Billet front cover
Short throw shifter with MGW ****
McLeod twin disk clutch
Mark Williams drive shaft and half shafts
Half Shaft safety loops
Quaife rear end
SUSPENSION / BRAKES / TIRES
OEM Koni shocks with Koni coil-over set up
Eibach Race Springs (spring rates = 450 fronts, 650 rears)
Roe/SRT front calipers
Roe 2-piece slotted rotors
CCW SP16A brushed finish with clear powder coat (19x11 fronts, 19x13 rears)
Hoosier A6 tires (295/30/19 fronts, 345/30/19 rears)
MISC./ACCESSORIES
Ultimate Pedals (brushed finish and non-slip design)
MGW gauge surround and HVAC *****
OEM aluminum gas cap (brushed and clear ceramic coated)
Autometer boost and fuel pressure gauges on A-pillar pod with LED shift lights
Greddy Profect B boost controller mounted in center vents with A/F gauge
For more pictures, please click the link below.
http://s228.beta.photobucket.com/use...brary/97%20GTS
2lflat4
11-18-2019 06:05 PM
stevenrmusic
Bentley
17
11-12-2015 06:53 PM
09-01-2015 04:16 PM
