FS: 2000 Audi S4 Stage 3 FAST!!
Year: 2000
Make: Audi
Model: S4
Price: $15000
Mileage: 149000
Color: Black
Location (State): VA
Transmission: Manual
Drivetrain: 4WD & AWD
I have over $20,000 invested in this car (I spent $6,000 at RAI in the past year getting the suspension and tune just right along with the regular maintenance items.) I have it set at stock ride height now (Arlington is bumpy), but a few turns on the coilovers and you can be slammed to the ground if that's your thing. It is mechanically sound and has had a lot of preventative maintenance done. I'd rate the exterior an 8 out of 10 and the interior a 9 out of 10.
Year: 2000
Mileage: 149,000 (will go up as it's my daily driver)
Factory options:
- white leather interior with black accents (I also have a set of silver accents if you prefer)
- sunroof
- Bose sound system
- cold weather package (heated seats)
- 2.7L twin turbo, Quattro all-wheel drive
Modifications and Maintenance:
- OEM RS4-K04 Turbos, Inlet Pipes
- Tune: started with a VAST performance stage 3 custom tune at 23psi, then had RAI Motorsports fine tune it with dyno tuning
- JHM front mount intercooler with black powdercoated pipes
- Bosch side fire spark plugs (#5's) cold
- OEM replacement ignition coils
- 034 85mm mass air, RS4 silicone hose, RS4 sensor, AEM dry flow filter
- EV14 52lb injectors, 4bar FPR
- Vast stage 2 clutch, vast 12lb lightweight flywheel
- SSAC 3" downpipes with 2 1/2" true dual-catback single muffler
- Stainless steel tubular manifolds
- Forge 50/50 splitter valves
- 034 motorsport street density motor mounts
- JHM short shifter
- Electric fan conversion
- New, adjustable ST coilovers (installed within the past year)
- Replaced all control arms
- AWE stabilizer bar
- 034 motorsport snub mount and cage
- Greddy turbo timer
- Vent boost gauge
- Drilled & slotted rotors with ceramic pads
- 18" BBS CH wheels
- Custom front bumper with RS4 replica grill
- Infinity reference door speakers, Kicker compV deck woofers, kenwood touch screen head unit dvd/mp3/ipod/usb
- Tint all around 35%
- Two sets of floor mats (cloth and rubber/winter mats)
- ECStuning EGT sensors, 2 new o2 sensors
- Brand new overflow tank and cap.
- water pump, timing belt, pulleys, tensioner.
- new front axles
- valve cover seals, timing chain adj. gaskets
- replaced all mirrors: rear view mirror and both side mirrors (the automatic anti-glare film corrodes after a while)
Price: $15,000
E-mail: johnrichardsonii at GMAIL dot com
Phone: 703 eight eight seven 8541
I don't check the forum that often these days, so calling/text/e-mail are the best ways to reach me.
I don't have a dyno graph to say, but it should be putting down around 400awhp +/- 25awhp. That's what B5 S4s with similar setups have been putting down. I didn't ask for a dynograph of total power output when it was tuned; I was only concerned about the AFRs. I could probably get another 50awhp out of it pretty easily if I added meth injection, but frankly it's already more power than I can use on the roads around here. Too many lights and traffic to really let loose, sigh.
2lflat4
11-18-2019 05:05 PM
awdbiturbo1
02-18-2016 10:24 AM
Nikg
09-21-2015 10:32 PM
