2002 porsche 911 turbo full build
Year: 2002
Make: Porsche
Model: 911
Price: $68500
Mileage: 39000
Color: BLACK
Location (State): Can-ON
Transmission: Manual
Drivetrain: Rear Wheel Drive
Motor
Full build by Protomotive as a 3.8 with Mahle internals. Full GT3 spec head work With new Stainless valves, locks, retainers, springs with GT3 cams intake and exhaust- O-ringed heads 12mm head studs installed. Lockwire Head Gaskets
Intake is 996 that was extensively Ported with an RPD plenum and a Cayman Throttle body, full polished 3" inlet pipe with Tial BOV
911Tuning stainless headers with HTA3586 Roller bearing turbos, New K&N filers mounted to turbos. 911Tuning 4.5" Intercoolers
New alternator
New under drive crank pulley
The motor has maybe 1200miles on it.
BBI New Hi output Coils
New NGK Plugs
Dual intank 0-44 pumps feeding a 1.5 Liter Surge tank into a Weldon 2345 Pump with Voltage regulator –
-12 feed line with a -8 return line
Trans
The trans is a fully built with all Gaurds parts
GT2 billet Mainshaft with gears changed out. 3 and 4 are the straight cut gears
2.49 first
2.56 second
1.632 ¾
Numeric Shifter
Numeric cup cables
LSD 40/60
Syvecs standalone. With ID2000 Injectors E85 Setup – tune by Magnus -882Whp at 22.4Psi Running Rich (will disclose More Info to buyer)
I have not set up with the traction control at the moment. I haven't played with it to much to be honest.
The standalone is very user friendly for Boost by gear and for tune ability it's great. You can install the flex fuel sensor and have the best fuel combo you can get.
You have the ability of multiple maps for fuel timing or boost a total of 12 different maps
Wideband O2’s
E85 setup has a very smooth idle.
Interior
White gauges – 39000 miles
Sport seats- Heated with Red painted backs
Red seatbelts
Factory roll bar
Alcantara hood liner
Greddys EBC still in car
Exterior
HRE R40 18” rims – Satin black
Toyo tires up front 235/35/18 and MT 295 drag radials on the rear. NEW never EVEN SPUN!
DSS Rear axels
PSS10 suspension
Techart GT full body kit Carbon chin spoiler with a spare
Paint correction 1 year ago / full cut and polish Pick the car up and go race the next day!
Car has never seen SNOW/salt/sand
996 front Diff that will go with it to bring it back to AWD
911 Tuning 3" stainless exhaust with no mufflers 2 100 cel resonators per side
All PMs replied to and as some one asked yes I would sell the car without the extra rims for a lower cost.
Would take $68000.00
