Audi Stage 3+ Built Engine/Trans Audi Allroad
Year: 2002
Make: Audi
Model: allroad
Price: $24000
Mileage: 87000
Color: Silver
Location (State): PA
Transmission: Automatic
Drivetrain: 4WD & AWD
ENGINE
2.8 cylinder heads
rs4 intake camshaft
Rosten piston rods
Autospeed (Also known as ASP out of NJ) fueling (630 cc siemens deka fuel injectors)
044 fuel pump
Swaintech friction coated main and rod bearings, thermal barrier on piston tops and cyclinder heads/valves
rs6 turbos
Ported intake manifold to match 2.8 heads
Phenolic intake manifold space
ER intercoolers
X1 carbon fiber intake
Devils own professional installed methanol injection system. This is tapped into the bi-pipe and is mounted in trunk.
Oil cooler
EXHAUST
RS6 Sound enhanced exhaust
3'' downpipes with high flow catalytic converters
TRANSMISSION
6 speed swap with kryo'd internals and new 1st, 2nd gear syncros
SouthBend Stage 5 clutch
Torsen 4:1 center diff (rear wheel bias)
TDI 6th gear -longer gearing for better gas mileage (or higher top speed).
trans cooler
INTERIOR
RNS-E Navigation system
Bluetooth hands free (works great)
IPOD integration
All Weather floor mats
European interior with door cards including Alcantara seats with door cards (probably the only car in the US with this interior. It was shipped from Europe).
Heated front and rear seats.
Heated steering wheel.
SUSPENSION/BRAKES
Replaced the ****ty air-ride with Variant V-3 coilovers. Adjustable dampening and rebound. These are awesome. Literally changed the way the car handled when installed.
ASP Drive train stabilizer.
Alcon 6 piston front brakes
S8 rear brake upgrade with Alcon rotors
EXTERIOR
Depo clear front headlghts
Professionally made RS4 grill (by a metal worker)
LED tails
Fully chromed BBS RS-GT 20x9 on cooper rs3-s filled with nitrogen
Comes with stock rims with winter Hancook Icebear winter tires
Painted fenders, front and rear bumpers to match body paint to give it the european rs4 widebody "look".
Again everything was professionally installed. Recently there was a turbo gasket that needed replaced, and a weep from the head gasket that was fixed. All those repairs were done by an audi certified tech that is also R8 certified. The only bad I can think of is the normal rock chips on the front, a scratch on the rear bumper that is in the picture. You can barely see it. Also, because of the TDI 6th gear it cruise control won't work due to the different gearing.
The car was dyno tuned by ASP and is conservatively tuned to 24 psi on meth and made 465 wheel hp on a mustang dyno. It could make 500 whp easy on the setup. ASP setup has made the car a wireless hot spot and I can change the tune on the car with an Iphone app I downloaded. There is a 93 tune, a 104 tune (meth), valet mode, and theft mode. It's a pretty awesome feature. The car is not a daily driver. It's driven once a week, but tuned such that it could be a daily driver and the feel is smooth. I've driven this car to the beach and back with no problems.
I'm sure I'm missing some modifications as I've dumped a ton into this car, but I can provide more pictures and videos upon request. Again, this car is literally one of kind.
great car... I had an '03 allroad that was modded to a stage 2+ and loved it. Put 220,000 miles on it as a daily driver. If AoA was still importing the A6 allroad, I'd buy another in a second.
Good luck with sale...priced well for all the work that you have in it.
Thanks, Joe. It's been a long road of work. Good to finally have done. I had a PPI done on it recently as well, but obviously would be willing to have another one done at buyers discretion.
I don't get how you guys can get the project done , spent 30k$ on it drive it for 5k miles and sell it .. since I put my s4 together 2 years ago I already put 35000 miles on it and not planning on selling it .
GLWS , nice car !
GLWS , nice car !
^^^^Mine's not a daily driver. That's what makes the world go round. Different strokes for different folks No room in the garage to get something new until I sell this.
Good to hear you like yours. This is the second built stage 3+ audi I've built/owned over the last 6 years. Ready for two doors.
