FS:TX 509ci 1969 Camaro RS Frame-off resto
Year: 1969
Make: Chevrolet
Model: Camaro
Price: $37999
Mileage: 1600
Color: PPG Clapton Green
Location (State): TX
Transmission: Automatic
Drivetrain: Rear Wheel Drive
This car was featured in the January 2002 Car Craft magazine with four dedicated pages and winner of 16 awards including Car Craft's Award of Excellence and Outstanding GM car.
Previous owner completed the frame-off restoration which includes over three years and 1600 logged hours on the build, $32,000 in parts costs. All framing and suspension is powder coated.
--Body--
-Original RS car
-Paint is PPG Clapton Green polyurethane with gloss black Baldwin Motion style stripping, four coats of clear, wet sanded and buffed
-Exterior stainless trim package, front spoiler, hideaway headlights, '69 Mach 1 rear wing. Complete with "509" fender decals.
--Engine--
-509ci (0.040" over) Cadillac engine from a 1970 Eldorado
-Forged crank, forged Olds 455 rods and clevite 77 bearings
-10.0:1 compression with Keith Black Hypereutectic pistons
-Ported and polished heads with stainless 2.19" int. and 1.90" exh. valves
-Rocker arm shaft conversion
-Comp Cams camshaft wit h.562 lift and 286 duration @ 0.006"
-Edelbrock Performer intake
-Edelbrock Performer RPM 850 CFM, blue Holley fuel pump with reg.
-MSD 8.5mm plug wires, blaster 2 coil, petronix ignition
-Cast aluminum valve covers with Cadillac script
-Custom headers
-Remote oil filter and heavy duty 4-core radiator
--Drivetrain--
-Rebuilt TH400 auto trans with TCI 2400 RPM stall
-Rebuilt 8.5" posi rear with 2.56 gears, moser axles, bearings and cast aluminum cover
-Custom 3" driveshaft with severe duty u-joints
-Willwood four corner disc brakes, 4 piston calipers, line lock and adjustable proportioning valve
-Steeroids rack and pinion power steering conversion
-Hotchkis suspension system with 2" dropped coil springs in front, 1.5" leafs in back, oversized front sway bar, KYB gas shocks, polyurethane bushings
-Bolt-on subframe connectors and Southside Machine traction lift bars
-16x8 Boyd Coddington Stingrays
--Interior--
-Houndstooth interior
Vehicle was purchased (2007) with 1200 miles post build, and to date has roughly 1600 miles.
After purchase, a weird tick resulting in random non-starts led us to a performance shop in Texas, where it was determined that the block was machined outside of tolerance for the crankshaft clearance. The shop (name escapes me at the moment) undertook a complete rebuild (new block), including new custom headers, and rebuilding the transmission properly.
The car was dyno'd at around 430 whp.
The car is an absolute beast and a pleasure to drive, my father has reluctantly decided to sell mainly because it is taking up space in the garage and clearly (400 miles in 7 years) never drives it. I would like to say that the engine is blueprinted, but until I get the last few documents from him I am merely speculating.
Once the last few documents are in hand I will edit and update with any new data.
If you have any questions, please feel free to email me at johnss001 @ gmail.com
I do not have the requisite PM count so I will not be able to communicate via private message.
