MUST SELL! Carrera C4 996 with 8k rebuilt motor
Old 12-10-2016 | 06:13 PM
blackonblack996's Avatar
blackonblack996 is infamous around these parts
Year: 2001
Make: Porsche
Model: 911
Price: $24499
Mileage: 104700
Color: Black Pearl
Location (State): UT
Transmission: Automatic
Drivetrain: 4WD & AWD
MOVING MUST SELL! Negotiable
Newly Rebuilt Motor, just 8,000 miles on it!
Color: Black Pearl Metallic. Year: 2001
Interior: Excellent
Exterior: Excellent
THIS is the used 911 you want. Here’s Why –
• There are a few common issues with a 996 series 911, and they are ALREADY TAKEN CARE OF by the recent professional motor rebuild (2016): IMS bearing, rear main seal, cylinder and block issues.
• WARRANTY: The rebuilt motor (MB Motorsports) comes with warranty both from the machine shop and the auto mechanic who installed it. This gives you financial confidence in this bulletproof-performance daily driver.
• Replaced...
o IMS roller bearing
o Restored cylinder heads
o Main bearings
o Rod bearings
o Piston rings
o Updated low-temp t-stat
o Timing chains
o Sliders
o Tensioners
o Seals, Gaskets, Filter
o Rear main seal
o Cylinder heads bolts
o Re-sleeved cylinders
o Air/Oil separator unit
o Spark plugs and tubes
o Porsche coolant
o Windshield
o Left headlamp unit
o Secondary air pump
o Secondary air injection system combo valve, shutoff valve, vacuum hoses (rubber)
o Front trunk latch cable
o Front and rear hatch shocks
o Front brake pads (rear pads some with, they weren’t worn down enough)
o Serpentine belt
o Idler pulley
o All weather tires replaced earlier this year when the brakes were done
o Cquartz ceramic-glass paint protection and gloss coat
• Motor was rebuilt to factory spec as 3.4L
• Non-smoker!
• No track driving or other racing – just a commuter car going to and from work
• Condition: Nearly 70% of the vehicle has been professionally repainted in 2016 through restoration. There are no door dings/dents. Interior and black leather is amazing.
o Restored/repainted: front bumper, rear bumper, right front fender, left front fender, front hood, side mirrors, roof was color sanded, new Hexmat rubber floor mats
• Car comes with a fresh oil, filter change and detailed interior/exterior
• Excel file with all maintenance done since I've owned the car – I’ll email it to you.
• Issue: Sometimes a CEL comes on for the Secondary Air System. Mechanic says inexpensive, does not affect performance, but can affect emissions test. Light spends more time Off than On. (Secondary Air System is bolted onto 911’s that come to the USA.)
• Free Delivery if to UT, ID, AZ, NV, CA
• Sfowler2@gmail.com
• 801-319-8489 m
• I’m a car geek and have really taken care of this car as well as performed extensive restoration to the motor, interior and exterior.
ID:	465682   Click image for larger version
Name:	IMG_3673 small.jpg
ID:	465684   Click image for larger version
ID:	465686   Click image for larger version
ID:	465687   Click image for larger version
