E46 M3 Dinan Stage II
Old 02-07-2018 | 07:55 PM
cagan1984's Avatar
cagan1984 is infamous around these parts
Year: 2003
Make: BMW
Model: M3
Price: $23500
Mileage: 88400
Color: Topas Blue
Location (State): OH
Transmission: Manual
Drivetrain: Rear Wheel Drive
I am selling my Dinan SII 88k miles which is a forum car and nicely taken care of. Its a 2003 model. Cold weather package - including front heated and memory seats. Harman Kardon speakers
I am the 3rd owner and the previous owner was a gentleman from forum. I have initially searched 6 months to find this car. The car was an SMG but converted to manual transmission and a CAE shifter has been installed.
It has the rare topas blau color with black leather interior. Clean carfax and no accidents.
Price: $23.5k
I have the full maintenance records to it. I have owned the car for the past year and I am really sad to let it go but need something bigger for my family.
Mods:
http://www.caranddriver.com/reviews/...specialty-file
Dinan Stage II package:
- Dinan cold air intake
- Dinan remote temp sensor
- Dinan larger MAF Meter
- Dinan Ported and Bored Throttle Bodies
- Dinan Stage 4 ECM Tune
- Dinan lowering springs
- Dinan Koni Sport Shocks (fronts replaced in recent past)
- Dinan Strut Tower Braces (Front and Rear)
- DINAN 3.91 Rear End Gearing
- Dinan front and rear struts
- CaE shifter
- Supersprint Street Exhaust
- StopTech ST60 Big Brakes
- Fall-Line Motorsports Under-drive Pulleys
- Replace RTAB w/Powerflex
- ECS tuning poly trans mounts
- ECS tuning clutch line
- Apex Arc wheels with 95% thread left Continental tires
- Alcantara shift ****
- Alcantara e brake ****
- Grom audio bluetooth connection
Maintenance
MileageDescription
1,174 1200 Mile Svc Mcars Only
5,477 Backrest/folding function seat
6,453 DME Component Failure
9,890 Maint Eng Oil Fisrt Service
9,890 SMG Chang Pin Assngmnt Relay
19,525 Main Brake Fluid Change
19,525 Rod Bearing Replaced
19,525 Program SMG CPU
19,525 Frnt Fgmt torn off
19,525 Main Inspection I
20,466 MAF Malfunction
20,706 MAF Malfunction
25,021 Main Cat Perf Malf
26,000 Oil/Filter Change Castrol 10/60 TWS
29,000 Replace RTAB w/Powerflex
32,000 Oil/Filter Change Castrol 10/60 TWS
38,300 Oil/Filter Change Castrol 10/60 TWS
40,000 Replace Coolant Thermostat
40,000 Replace Drive Belts
40,000 Fix Evaporative Sensor
44,974 Oil/Filter Change Castrol 10/60 TWS
49,000 Replace Brakes (Rotors & Pads - EBC Red)
52,500 Oil/Filter Change Castrol 10/60 TWS
53,000 Replaced DVD Drive on Navigation System
54,950 New Goodyear Eagle Asymetric Tires
54,950 Service Differential w/BMW Specific oil and additive
54,950 Service Manual Transmission w/BMW Gear Oil
54,950 Service Cooling system - BG Flush and replace with BMW Coolant
54,950 Service Pwr Steering BG Flush
54,950 Replace Fuel Filter
54,950 Replace Brake Warning Sensors
54,950 4Wheel Alignment
55,400 Spark Plugs Replacement
55,400 Valve Adjustment - 2 valves were reshimmed, the rest were fine
55,400 Replace FCAB OEM
55,400 Brake Fluid Bleed
56,000 Stoptech ST60 big brakes installed
57,860 Oil/Filter Change Castrol 10/60 TWS
63,200 Oil/Filter Change Castrol 10/60 TWS
67,000 Swapped out SunRoof cassette
68,840 Oil/Filter Change Castrol 10/60 TWS
69,000 Replaced intake cam sensor to fix P0340, P0011 & P0012
71,000 Replaced Tires Michelin Super Sport 245/35/19 & 275/30/19
75,000 Oil/Filter Change Castrol 10/60 TWS
76,500 Replaced intake cam sensor to fix P0340, P0011 & P0012
77,000 Replaced Throttle Position Sensor to fix EML
80,450 Oil/Filter Change Castrol 10/60 TWS
80,890 Replaced Throttle Position Sensor to fix EML
82,000 Replaced throttle actuator and Temp Sensor and checked vanos
84,000 Apex wheels/ continental tires installed
85,000 Oil and filter changed with Rowe 10W/60
88,000 Car swapped from smg to MT with brand new parts
88,000 CaE shifter installed
88,000 Vanos and subframe inspected
88,000 Oil and filter replaced with Liqui Molly 10w/60
88,000 Grom Audio installed
88,000 Alcantara shift boot & e brake installed
88,000 Alternator replaced with new
88,000 Battery replaced with bosch
88,000 Drive belts replaced & AC belts & drive and tensioner pulleys
88,000 Transmission fluid flushed
88,000 Differential fluid flushed
88,000 Maf cleaned
88,000 Front windshield replaced
88,000 New Dinan Air filter replaced
88,000 Steering pump fluid added
The interior condition of the car is really good and clean. I have also just installed an alcantara shift boot and e brake both Genuine BMW; as I was just installing the CaE shifter.
The exterior color is in really good shape and the interior is really in good condition for the age of the car.
The bad:
- A & C pillars sagging
- For CaE shifter install the trim around gear shifter & cigarette lighter had to be cut (but won't be noticed as the shift boot covering it)
- A small door ding on the passenger side
- Another small deep scratch/dent on the door
Overall a really nice car which has never been tracked and really well taken care of m3 enthusiasts with a rare color.
I am in Cincinnati and please let me know any questions that you may have other than what I have highlighted here.
ID:	520477   Click image for larger version
ID:	520478   Click image for larger version
ID:	520479   Click image for larger version
Old 02-07-2018 | 09:51 PM
arjayr33's Avatar
arjayr33 has a reputation beyond reputearjayr33 has a reputation beyond reputearjayr33 has a reputation beyond reputearjayr33 has a reputation beyond reputearjayr33 has a reputation beyond reputearjayr33 has a reputation beyond reputearjayr33 has a reputation beyond reputearjayr33 has a reputation beyond reputearjayr33 has a reputation beyond reputearjayr33 has a reputation beyond reputearjayr33 has a reputation beyond repute
how do you like the CAE shifter? nice DD
Old 02-08-2018 | 06:53 AM
cagan1984's Avatar
I really like it Arjay its the first time I installed such a shifter but I think its worth it...makes the shifting a joy
Old 02-08-2018 | 02:08 PM
Lennon31987's Avatar
Lennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond repute
beautiful car....gl with sale, makes me miss my e46 like WHOAAAAAA
Old 02-08-2018 | 08:19 PM
cagan1984's Avatar
Thank you so much...it really is a beautiful chasis
churious
04-22-2011 10:55 AM
ThisFlyGuy
03-26-2008 01:01 AM
K04
01-14-2007 11:11 AM
Quick Reply: E46 M3 Dinan Stage II
