2009 GT-R (TSM Built BL1200x) 1400HP 300 Miles – Virginia Beach, VA
Year: 2021
Make: Nissan
Model: GT-R
Price: $78500
Mileage: 520
Color: Black
Location (State): VA
Transmission: Automatic
Drivetrain: 4WD & AWD
Make: Nissan
Model: GT-R
Price: $78,500 FIRM
Chassis Miles: 58,xxx
Motor Miles: 520
Transmission: Auto DCT
Drivetrain: AWD
Private Sale: I have the Title in hand
Local Pickup: Yes
Transport: Yes (Buyer expense)
Ship International: No
Payment: Bank Loan / Wire Transfer
Returns Accepted: No – Sale is final
Trades: No
Test Drives: Yes, for a serious buyer with a deposit
PPI: Buyer’s responsibility if requested.
Reason for Sale: May switch to a different platform
Well taken care of and fully built 2009 Nissan GT-R Premium (Black/Black) with a built 2012 DBA Trans. The car makes ~1,150whp on a DynoJet (low boost 32psi). This setup should be easily capable of making 1400whp if you wanted to increase the boost, which I have not done as this has been plenty of power for me. It has been meticulously cared for, although it is a 2009, so there is normal wear/tear as expected. That being said, the car is in phenomenal condition for it to be ten years old. No expense was spared when building my car, and it was built with some the best parts on the market.
The car is priced fair for the amount of modifications. This is the best car that I have ever owned! It has all the power you could ever want and you can take it to the track or the grocery store. It starts up every time with zero issues. I will continue to drive the car on weekends until a deposit is paid, so the mileage may increase slightly from the above figures.
Feel free to contact me day/night at kesslerm1987@gmail.com or 360-929-7006 (text or call).
Fully Built TSM/BL1200x – Motor build only has ~300 miles on it (01 June 2019).
Build was completed with BRAND NEW OEM Nissan Shortblock, Crankshaft, Cylinder Heads, and Timing Covers
Engine Modifications - $21,135
TSM Built Street Short Block - $7,000
· TSM Spec Machine Work
· TSM Spec Oiling Modifications
· TSM Spec CP Custom Pistons
· TSM Spec Carrillo Connecting Rods
· Nissan Bearings (Not stock sizing)
· ARP 2000 Main Studs
· Over Balanced Rotating Assembly
· Precision Assembly
CNC Ported Race Cylinder Heads - $6,000
· Race CNC Ported Intake/Exhaust Ports
· Race CNC Ported Bowl Work
· GSC Bronze Valve Guides
· GSC High Pressure Conical Valve Springs/Ti Retainers
· GSC Valve Seals
· GSC +1mm Oversized Intake Valves
· GSC +1 mm Oversized Super Alloy Exhaust Valves
· Tomei Pro 282 Camshafts (New VALC Style)
Nissan OEM Timing Chains/Tensioners/Pulley/Oil/Water Pump - $1,000
Nissan OEM Master Gasket Rebuild Kit (all new gaskets) - $300
Nissan OEM 2016 Bell Housing Upgrade - $1,100
Boost Logic PNP 3port Electronic Boost Control Solenoid - $200
Boost Logic Catch Can (AOS) - $1,000
Boost Logic Deep Sump Engine Oil Pan - $800
Boost Logic Coolant Overflow Tank - $500
TSM Large Oil Filter Adapter Kit - $175
TSM Custom Spec Head Gasket - $350
TSM EGR/Air Pump Delete Block Off Plates -$50
ARP 625+ Head Studs - $850
AMS Alpha Engine Oil Cooler - $1,000
GotBoost Speed Density A Kit - $430
Omni 4Bar MAP Sensor - $130
Cobb AccessPort V3 w/TCM - $1,350
· TSM ECU/TCM Tunes. Boost settings can be adjusted by the flick of a switch on the steering wheel. You have up to 5 settings for different power levels
Transmission Modifications - $14,000
Fully Built 2012 DBA Transmission - $14,000
· Linney Billet 1-6 Gearset
· 18 Plate Clutch
· Billet A and B Clutch Baskets
· Carbon Clutch Seals
· Billet Drop Gears
· Modified Synchro Sleeves
· Billet Deep Sump Oil Filter
· Oil Pump Modifications
· 10 Plate Carbon ETS
Turbo/Induction Modifications - $19,150
Boost Logic 1200x (66mm Race Version) Turbo Kit - $10,000
· Includes Custom 3.5” Titanium Inlet Pipes, IC Pipes, Water Lines, and Oil Lines
Boost Logic Intake Manifold V2 - $3,500
Boost Logic Race FMIC - $3,000
Boost Logic Full Intercooler Piping Kit w/ Tial 50mm BOVs - $1,600
Boost Logic 3.5” Burnt Blue Titanium Intakes - $1,050
Fueling Modifications - $6,940
AMS Omega Dual Brushless Fuel Pumps - $3,300
AMS Omega Fuel Rail Upgrade Kit - $1,100
· Includes Fuelab Regulator, Rails, and Lines
ID1700 Injectors - $1,740
GotBoost Flex Fuel Kit for AMS Rails - $800
Exhaust Modifications - $3,700
ETS Pro Series 3.5” Vband Downpipes - $1,000
ETS Pro Series 3.5” to 4” MidPipe - $900
Fabworx 4” Exhaust with Titanium Tips - $1,800
Suspension Modifications - $3,550
KW Sleeve Kit - $1,300
SPL Titanium Front Upper Camber/Caster Arms - $1,250
SPL Titanium Rear Camber Links - $500
SPL Titanium Rear To Links - $500
Brake Modifications - $2,200
BDA T3 5000 T-Slotted Front Rotors - $800
BDA T3 5000 T-Slotted Rear Rotors - $800
Hawk Street Front Brake Pads - $230
Hawk Street Rear Brake Pads - $170
ARP Extended Wheel Studs - $200
Wheels/Tires - $6,794
Advan GT Wheels 20x10/20x12 (Black Semi-Gloss) - $4,500
Advan Full Flat Center Caps - $224
Toyo R888R 285/35R20 (75% Life Left) - $900
Toyo R888R 325/30R20 (75% Life Left) - $1,050
Wheel Mate SR48 Lugs/Locks w/key - $100
Wheel Mate Billet Black TPMS Stem Covers/Caps - $20
Mount and Balanced with Black wheel weights
· The sale will also Include the OEM Wheels (Powder Coated Black) with MPSS Tires (50% Life Left)
Aero Modifications - $830
Difflow Rear Diffuser - $830
Misc - $710
Escort Passport 9500iX Hardwired Radar Detector - $400
GT-R Cargo Net - $25
Car Cover - $200
WeatherTech Floor Mats - $110
State Legal Tint
Clear Bra Front Bumper and First 1/3 of the hood
_____________________________________________
PRICE: $78,500 FIRM ($100,000+ Invested in modifications alone)
I can send more pictures and videos if interested. Feel free to contact me day/night at kesslerm1987@gmail.com or 360-929-7006 (text or call).
Serious inquiries only. I will offer test drives with a deposit. There is nothing wrong with the car and it is in full working order. Come ready to buy!
-Mike
Last edited by Navy_Mike; 02-23-2020 at 05:31 AM. Reason: Lowered Price $ Increased Mileage since I've been driving it
Thank you.
Thank you. Yes, it is still AWD.
I appreciate all the emails and interest in the car. She is a amazing machine!
-Mike
-Mike
-Mike
The new owner will get an amazing deal with this car. If you want to be the next owner let me know
-Mike
Car is still available. Price is $82,000 OBO. This is a phenomenal car for the price. Text me at 360-929-7006 or email kesslerm1987@gmail.com if you have any questions.
- Mike
- Mike
- Mike
