Restored and Lifted 1975 Ford Bronco
Year: 1975
Make: Ford
Model: Bronco
Price: $39500
Mileage: 250
Color: White
Location (State): NC
1975 Ford Bronco Sport 4x4
Beautifully Restored
Suspension Lift
LOW Mileage (75,000 ORIGINAL miles) ... only 250 on restoration
Some details:
- When I bought the truck, it had a good amount of rust. All was removed and replaced
- 6 inch Wild Horses suspension lift (no body lift) and new-ish 37" tires (under 1,000 miles)
- Rebuilt 302 motor (rebuilt within the last +/-5 years)
- 4WD with Chromoly Dana 44 front axle and twin-stick setup
- C4 Automatic Transmission and Cheetah SCS Shifter (Shifter not replaced during restoration, but does have newer transfer case)
- Dual fuel tanks with "on the fly" changeover (each tank has it's own independent pump, wired to ignition, with on/off switch on the dash)
- Power steering and power disc brakes
- Bright white paint with satin black accents (bumpers, fender flares, logos, trim, etc.)
- Most everything replaced with new (door panels, seats, LED headlights, steering wheel, rhino-lined interior, etc.)
I do have satin black hardtop and rear seat neither currently on/in the truck, but both come with the truck. The only issue with the truck is a downshift lurch from 3rd to 2nd... This is a relatively new issue and is a result of something in the twin stick that I can't quite figure out. I still drive it regularly, but the downshift is harder than the other shifts. Happy to take to a mechanic for PPI to confirm it's not a major issue.
jmontoya
08-11-2012 10:50 AM
