2002 Porsche 911 Turbo - 6 Spd - RWD Conversion - 600+HP
Year: 2002
Make: Porsche
Model: 911
Price: $48000
Mileage: 59500
Color: Basalt Black Metallic
Location (State): PA
Transmission: Manual
Drivetrain: Rear Wheel Drive
2002 Porsche 911 Turbo (996)
59,XXX miles
Basalt Black Metallic / Black Interior
Carbon Package
Clean title / No Accidents
One of the previous owners desired a GT2-like car without paying the GT2 price and had this completely converted into GT2 spec with UMW K16/24 hybrid turbos, GT2 upgraded intercoolers, GT3 suspension/brakes, etc. It was meticulously owned and almost every single part has a receipt/documentation and comes with the car in a 50+ page binder. I personally had the car PPI'd by two Porsche shops and it is mechanically sound. Receipts totaling over $65K.
Engine:
Removed at ~40K at LMN Motorsports
Welded ALL Coolant Lines
New OEM Radiator Hoses, Intercooler Hoses, ALL hoses radiator to engine.
UMW Zero Clearance Turbos (K16/24 Hybrids)
UMW Tune
997.2 Intercoolers / Coil Packs
Fabspeed Stainless Headers
Fabspeed Exhaust - Modified with X-Pipe
Drivetrain:
RWD Conversion - Professionally converted, axles & front differential removed, capped
996 GT3 Cup RWD Rear Differential
UMW Clutch Kit (Sachs GT2 Clutch, Pressure Plate)
GT2 EVOMS Clutch Slave
OEM 997 Shifter
EVOMS RSS Motor Mounts
GBox 2nd Gear Detent
Suspension/Brakes/Wheels:
996 GT3 6-Piston 350mm Front
996 GT3 4-Piston 350mm Rear
Replaced OEM Brake Lines
Bilstein PSS10 Coilovers
Eibach Rear Sway Bar
TPC Drop Links
Replaced ALL Wheel Bearings
BBS CH-R 19x8.5 et52 F / 19x12 et45 R
Bridgestone Potenza 235/35/19 F / 305/30/19 R
Misc:
Full Professional Paint Correction & CeramicPro Ceramic Coat (Just done last week)
Misha Designs GT2 Deck Lid & Wing
Kenwood DNX891, Alpine Amps, JBL/Infinity Speakers
Cons:
Speakers need checked, some have no sound. Could be loose connection.
Alternator whines a bit occasionally due to audio system, or AC
Steering wheel crack in Carbon at 12:00 position
Small quarter-sized paint bubble on front bumper
If interested, please text only (267) 317-9811
Very nice rendition of a GT-2 and it's cheap too. To go back to AWD is inexpensive and if you do you may upgrade to a 997 front drive. I had an 02 GT-2 all stock they're wonderful car and fast!
The removal of the AWD system improves driving feel at the limit compared to AWD. They are a riot in RWD configuration. So much fun. Snow tires for the winter and that car would be great in winter.
