2005 Evo MR
2005 Evo MR
2005 Evo MR, 15,000 miles. Slightly modded. Have stock parts as well. This car is a rocket.
$28,000
The MR is the top of the line Evo, only 1,000 made. The MR has the following standard, in addition to the base Evo:
It looks and drives totally stock- you wouldn't know any mods were done until you step on the loud pedal, then WOW.
4 DE days. In addition to the following, I have harnesses, track pads, track tires and winter tires included.
Vishnu mods: (the absolute top Evo tuner imo)
Stage 1++ 450 hp
Passive Boost Solenoid Emulator
3” Turbo-Back Exhaust
Signature Series 3" Down-Pipe with Catalyst Bypass
Pre-Set Adjustable Camshaft Gears
HKS Upgraded Camshafts
Upgraded Fuel Pump
Also included:
XEDE switchable program ECU, 91/100 octane
XEDE engine computer, Plug-in harness, Serial cable, O2 eliminator, Knock Signal Buffer.
$28,000
- 6-Speed, Close Ratio Manual Transmission
- BBS Forged Alloy Wheels
- Shift Panel "MR" Identification Plate
- Bilstein Front & Rear Shocks
- HID Headlamps
- Aluminum Roof
- MR Edition Floor Mats
- MR Edition Exterior Badge
- Wheel Locks
- Vortex Roof Spoiler
- Aluminum / Carbon Fiber Brake Grip
- Aluminum Shift **** & Sport Pedals
- Turbo Boost Gauge
Stage 1++ 450 hp
Upgraded Fuel Pump
Also included:
The factory ECU programming is very inadequate for stock or modified cars. Once plugged in, the XEDE will yield a 20-50hp gain
depending up on application. The XEDE also holds two maps that can be toggled back and forth if desired. Controlling fuel, timing
and boost, the XEDE is a complete engine control solution for any application imaginable
Hotchkis Sway Bar
Also included: V1 hardwired with concealed display mounted to the left of the dash, Lidatek laser diffuser
with LED inside V1 concealed display, full front end and side mirrors clear bra, and 50% tint all the way around.
Hotchkis Sway Bar
Thanks for the replies, I will take some pics when this damn blizzard blows through.
Funny thing is this car has never given me a minute of trouble, not a squeak, rattle or anything else. Wish the Germans were as reliable.
I'm just doing the spring shed Marc.
-P
-P
10-02-2015 02:23 PM
ModBargains.com
996 Turbo Vendor Classifieds
10-01-2015 11:48 AM
