911 Turbo Coupe - Speed Yellow, 6 Speed, Full Leather, Clean Carfax THIS IS THE ONE!
Year: 2001
Make: Porsche
Model: 911
Price: $59950
Mileage: 79800
Color: Speed Yellow
Location (State): IL
Transmission: Manual
Drivetrain: 4WD & AWD
Car needs NOTHING! If you're looking for a Turbo that is well sorted out, then look no further, It took my almost 1 year to find this after chasing only a handful available throughout the country in 2019. The car has lived a great life in Florida for most of its life and just recently came to the Chicago area when I purchased it in 2019. The CarFax report shows a very strong maintenance history from the beginning. I had a Porsche racing shop and a Porsche repair shop go through the car with PPIs and fix things that were not up to par. Most recently, it was freshly serviced within the last 500 miles at a local independent Porsche shop. The vehicle has a fresh set of Michelin Pilot Sport 4S tires within the last 3,000 miles. The paint has been metered TWICE, by two different shops for a PPI when I purchased it from Florida, HOWEVER the one thing that has been painted was under my ownership has been the deck-lid. Nearly all rear deck lids on Speed Yellow 996s fade for some reason and the color doesn’t match the rest of the car at some point. A local Porsche Certified body shop was able to color match the deck-lid back to new.
The car drives amazing and the full Tubi exhaust system creates such an amazing sound that it makes you want to lower the windows and turn off the radio. Every aspect of the driver’s experience is enhanced by the best-of-breed modifications - starting with a carbon fiber flat-bottom steering wheel, Numeric short shifter, lightweight flywheel, Alpine Car Play capable head-unit with rear-camera, Tubi exhaust system, lowering Champion Motorsports springs, tightening H&R adjustable front/rear sway bars, insane Brembo 380mm braking system, and a conservative 1-bar ECU tune that slams you into the seats after the turbos spool up. Everything on the car is easily reversible to factory specs because everything is a bolt-on modification so if the modifications aren’t to your liking.
The condition of the car is overall above average. There are a number of small chips on the car which are normal for age/mileage. The interior is in above average condition for the age and everything works as it should. This car will not disappoint if you're looking for something eye catching, fast, and well sorted.
WALK AROUND VIDEO:
YOUTUBE REVIEW OF 911 TURBO BY SAVAGEGEESE USING MY CAR (I changed out wheels/wing/led lights since then):
FACTORY OPTIONS:
BASE Porsche Base Model
059 Delete Front Bumperettes
680 Digital Sound Package
692 Remote CD Changer (6 Disc)
696 AM/FM Radio with CD Player
AD Black - Full Leather Interior
M6A Black Mats - Porsche lettering
P11 Self-Dim Mirrors & Rain Sensor
X4 Speed Yellow
X70 Metal Door Sill Model Insignia
TOP-OF-CLASS MODIFICATIONS:
- 19” BBS CH-R Wheels ($3,000)
- 6-Piston Brembo GT Front 380mm/ 4-Piston Brembo GT Rear Brakes 380mm ($8,400)
- Lightweight Flywheel (Previous Owner - $1,000)
- Sachs 2.5 Clutch (Previous Owner - $2,100)
- GT2 Slave Converted (Previous Owner - Reversible)
- Tubi Exhaust with Tubi Tips ($6,880)
- Evolution Air Intake (Previous Owner - $650)
- ECU tuned to conservative 1 BAR (Previous Owner - $800)
- Champion Lowering Springs (Previous Owner - $400)
- H&R Adjustable Front/Rear Sway bars ($650)
- Elephant Racing Wheel Studs ($180)
- Future Classic Porsche 15mm Wheel spacer kit ($205)
- Numeric Racing Short Shifter ($700)
- Carbon Fiber Steering Wheel ($700)
- Alpine CarPlay head-unit with upgraded speakers and rear camera ($1,000)
PAINTWORK:
- Rear deck lid resprayed with digital color matching by Porsche Certified body-shop in 2020 due to normal Speed Yellow fading. (2020)
REPAIRS UNDER MY OWNERSHIP TO GET IT UP TO SPEC:
- Replace/Repair Spoiler Hydraulics by Cabriolet Hydraulics (2019)
- O2 Sensors (2019)
- Rebuilt Front CV Boots (2019)
- Front Sway Bar Bushings (2019)
- Passenger Window Regulator (2019)
- Driver Door Actuator (2019)
- Washer Pump (2019)
- Headlamp Switch (2019)
- Ignition Switch (2019)
- Replacement set of Owners Manuals (2020)
- Renn-fix Light Savers (2020)
- Rear-view mirror repair by Radar-Mirror (2020)
- Michelin Pilot Sport 4S Tires (2021)
- Misc. screws/fasteners/clips (2019 - 2022)
cryptomonops
03-21-2022 06:43 AM
Marpir821
03-17-2022 05:18 AM
Brendon1098
01-10-2022 01:48 PM
