1999 996 cabriolet c2, 6 speed manual, 119k miles
Year: 1999
Make: Porsche
Model: 911
Price: $19500
Mileage: 119k
Color: silver
Location (State): CA
Transmission: Manual
Drivetrain: Rear Wheel Drive
1999 996 cabriolet c2, 6 speed manual, 119k miles, clean title, new dual row IMS and AOS. Also new water pump, thermostat, spark plugs, fuel filter and all fluids changed within the last 3k miles. Gbox detent was installed while the transmission was out to prevent 2nd gear pop out issue.
Suspension-wise the car is lowered on H&R springs, with new bump stops, tie rod ends and sway bar end links. The differential was replaced with a 996.2 newer unit with stub axles and new carrier bearings. The newer diff is stronger with 4 spider gears vs 2. The car comes with BBS GT3 wheels.
Black leather interior is in mint condition, with an Android head unit for Bluetooth connectivity and USB. A short shifter was fitted that's a vast improvement over stock, and the center console hinge was upgraded to metal as they're known to break easily.
Exterior is good for its age with minor door dings. Soft top was replaced before. Plastic rear window is clear and in good shape. Hard top and wind deflector included. Clean title in hand. Registered thru 6/2025. Located in Newark, CA, asking $19,500.
Make: Porsche
Model: 911
Price: $19500
Mileage: 119k
Color: silver
Aztectt
09-30-2024 12:48 PM
spooled951
12-30-2019 01:39 PM
