FS: HRE C93 18'' Wheels! Asking only $2,500!
Hi, I'm selling my 18'' HRE C21 rims. Front 18 x 8 (48ET) / Rear 18 x 10 (39ET). They were used on a narrow body 996, only for a few months, and are in near perfect condition. Centers are powder coated black, lip is polished. Asking only $2,500... and I'm sure you guys already know that these things are over $6k new and the strongest/lightest wheels you can buy
P.S. Will take some pics tomorrow.
That is too bad. However although they are for NB, I think there is a possibility that they will prolly fit with spacers since they are fairly wide even for NB. I'll call HRE tomorrow and see what they tell me...
Not to interlope, by couldn't you use spacers? I was stuck the other way around. Trying to fit WB wheels on a NB car and couldn't pull it off. You may be able to get away with just a set of rear spacers depending on the offsets.
as far as i know, the wide body cars are like 4.5 inches wider overall.. that leasve about 2.25" on either side. I think a spacer that size is excessive and really messes things up in terms of suspension geometry, etc. I would be curious to see what HRE says and what kind of spacer would be required. I would think that the best method to make these wheels "fit" is to swap barrels to a setup for a widebody car.
Still available. Looks like I made a slight error guys... the model is actually C21 (not C93) and fronts are 18x8, the offsets are 48 front and 39 rear. The rears have a 3' lip. The back barrel is 7'.
I thought I had adequately edumacated myself on wheel sizes/offsets and could start giving back to the Board (my first shot), having just wrapped up my hunt for 997 wheels. But your post points out that the 996 sizes may be different than for the 997 (which I hadn't considered), because in the case of the 997 (at least I believe) the only difference in the 19” wheels between the WB and NB is the offset. Oh well, back to my day job (while I still have one)...
thanks for the info. I replied to your PM.
WheelB
01-06-2018 11:08 AM
awdbiturbo1
02-18-2016 10:24 AM
ModBargains
08-20-2015 12:28 PM
