NEW Protomotive 700rwhp kit feeler
I have a complete (NEW) Protomotive 700 kit, this would include Todds intake with blow thru maf power coated silver, 60# injectors with adapters, dual pump kit, boost controller, 24/20g turbos, diverter valves, Sachs clutch kit Todd sells for his 700 kit, proto tuning, b6 intercoolers (to use, they will require modifing the outlet to 2.5" hose end) I think this is the same set up Ben (BMOORES) broke 200 mph in Texas with. $17000.00 invested open to offers.
I also have a set of GT30/76r AR .82 turbos off Scotts (divexxtreme) car when he went to GT35's $1750.00
Thanks Greg
Thanks Greg
I also have a set of GT30/76r turbos off Scotts (divexxtreme) car when he went to GT35's 1750.00
Thanks Greg
Thanks Greg
700 proto
after doing a motor build, GT3 cases, ported heads, lsd, I wanted to make the 25k spent on the upgrades worth while, so I am going to alpha 30/76 turbos, Marski's intercoolers, and e85 so if I can sell this I will go with Tony at epl for the programming he has done several.
i would markskis turbos also i have them and they rock !! i woul still do the Y pipe and intakes .
turbos
the only reason I did not go that way is because I am going to keep my europipe 2 loud and Marski's set up doesn't work with stock muffler placement and I did not want the noise of external wastegates.
Good luck with sale. Someone will get a great kit.
700 proto
Ben, The reason I am offering the intake is EPL does not tune on blow thru with ford maf and I thought the complete kit would look more appealing.
I was supprised that you ran over 200 most of the cars that did that had built motors lots of $$$ in them. great job to you and the Proto set-up.
WOW Great kit! good luck i went 136 with the exact kit your selling.
If its any consolation run the external waste-gates back into the exhaust no noise and it still runs nails!
But thats my opinion and i personally love the way my car runs and if it had your built motor i would still stick with that kit and just upgrade to the larger 30's or 35's no questions asked!
Best of luck!
Best of luck!
700 proto
Thanks, you car is making great power, I can't wait to so the 60-130 and 1/4 mile times. I am trying to keep the stock sound, sleeper like KPG.
Best of luck!
Best of luck!
x50 , epl will tune anyway you want , tony us good like that , he tuned alot of blow through set ups. powells included, i would keeo the y pipe and intakes, and if u dont like that external noise they can easyly be re routed into the exhuast .
700 proto
thanks, I talked to Tony and he said he does not tune blow thru with the ford maf, I would have to install a bosch maf and I don't think that will work with the proto intake set-up. Correct me if i am wrong.
Best of luck!
Best of luck!
thanks
