Snap On Tool Box and Tools
Category: Accessories
Price: $10000
Location (State): CA
Item Condition: Brand New
I have more pictures for anyone interested.
Contact tim@autobaron.com
Video Stick Bore scope protection mats Rolling Snap on box (kevin Harvick ) Snap on side cab Stainless steel top Eight way slide hammer Slap Hammer Leak Down Tester Compression tester Heat Gun Fluke meter with leather case Various VW/Audi valve adj tools Digital infrared tester gun Digital probe tire temp Shock nitrogen compensation guage electric drill with bits Cordless electric impact 1/2 inch with sockets Snap on Air Sander Long die grinder Chigago Numatic Die grinder Right angle 3/8 drive air gun Air sander blupt 1/2 inch air impact gun 3/8 air impact gun 1/4 air rachet with head cover 3/8 Air rachet with Head Cover 1/8" shank burr kit 3/8" Air Drill 1/2" Air Drill cobalt drill set Long air blow gun hole cutter Kit hole saw kit 1 set Lg Rottabroach style cutters left hand extractor set blue point folding box cutter in leather case Retracting box cutter x acto knife assorted punches 2 body dollies assorted hammers including Soft, brass, dead blow and claw 3/8 drive wobble extension set 3/8 drive extension set knurled Full set of Martin Wrenches Hex socket set (allen) 3/8 standard drive Hex socket set (allen) 3/8 metric drive three extra 8mm allen socket 3/8 drive 3/8 universal metric socket set 3/8 drive metric crowsfoot set (10pc) 3/8 drive standard crowsfoot set 3/8 drive with 1/4 style handle compact fixed 3/8 drive swivel head 3/8 drive torque wrench (inch lb) 3/8 drive torque wrench (ft lb ) rachet 1/2 drive torque (ft lb) rachet 3/8 drive speed handle 3/8 palm rachet 1/2 breaker bar 3/8 standard shallow socket set (11pc) 3/8 standard deep socket set (11pc) 3/8 metric shallow socket set (12pc) 3/8 metric deep socket set (12pc) 3/8 thumb drive extension 3/8 standard rachet (2) 3/8 fixed long handle rachet 3/8 swivel long handle rachet 3/8 long handle breaker bar 3/8 stubby flex head Rachet Pry Bar set (4pc) Screwdriver set flat and philips 8pc Long shaft screwdriver set flat and philip 8pc Convertible Rachet Screwdriver non snap on Dzus screwfastner screwdriver Set of jewler screwdrivers 1/4 long breaker bar 1/4 swivel rachet long 1/4 fixed rachet 1/4 standard (short) rachet 1/4 american deep socket set (10 pc) 1/4 shallow socket set (10 pc) 1/4 metric semi deep socket set (12pc) 1/4 metric shallow socket (12) 1/4 american Allen (socket head) socket set (10) 1/4 metric Allen (socket set) (10 pc) 4 ball style and 6 standard style 1/4 metric Swivel socket (4pc) 1/4 variangle Extension set (6pc0 1/4 3mm long Allen (socket head) socket (6pc) Femal torx Socket set 3/8 (5pc) 1/4 (5pc) Male torx Set 3/8 (7pc) 1/4 (5pc) Matco thread chaser American & Metric thread file (male and female) Rivet gun with rivets and rivet drill bits Tie rod splitter Universal stud puller Steering wheel removal kit 2kits-2 styles Pulley removal kit Bubble flare kit Adjustable locking hod prop rod Standard length deep 60 degree box wrenches metric Ratchetting box open metric wrench set (12 pc) Short handle metric combination wrench set (10pc) metric flare nut wrench set (10pc) metric combination wrenches (17pc) flex combination (open and socket style) (4pc) 3 Slimline wrenches metric 17mm 19mm 21mm American Flare nut wrench (5pc) American combination wrench set (21pc) Two american offset wrenches Assorted snap ring pliers (7pc) Assorted pliers including: Long needle nose Short needle nose Mini bolt cutters Upolstry button removal tool Side cutter Flush cut cutter spark plug wire cutter and crimper offset Shear Standard sheer wire stripper and cutter Braided steel line cutter Pro hose crimper Spark plug boot pliers
There is over 30k invested in the tools etc. The seller has been hit with some bad times and is forced to liquidate some of his possessions. Many sad stories in these times.
ModBargains
McLaren Vendor Classifieds
10-13-2015 03:41 PM
ModBargains
10-13-2015 03:40 PM
arhim22
09-07-2015 08:49 PM
