Help adding inline Bosch 044 Fuel Pump.
I am looking to add an inline 044 pump instead of the fuel filter in the same location. Does anyone know what fittings I need to do this? I am owrried about the plastic line on the fuel filter.
Here is what I found so far:
Pump intake is M18x1.5
Pump out (pressure side) M12x1.5
Filter is M14x1.5 on one side and a weird plastic hose on another side.
Has anyone done this DIY?
#TeamAIM
#TeamAIM
Looks like a bonjo from the filter to the rail. Is that a rubber line going to the rail?
#TeamAIM
#TeamAIM
Tom
bonjo or that red fitting?
#TeamAIM
#TeamAIM
Banjo = bad. Use a smooth radius fitting.
..... AND PUT A LOW FUEL PRESSURE SENSOR IN.........
If the fuse blows / 044 fails you will be pushing thru a huge restriction, and not have any way of knowing while you are driving.
I talked to him. I'd buy it if it wasnt a 1000$
I am also considering doing a GT2/GT3 intank pump because it would be easier. Part number is 996-620-057-92
#TeamAIM
#TeamAIM
is the gt2 a single intank sump? if so i doubt it will be enough to move the amount of fuel you will need for big boost and turbos.
imo spend the money and get markskis kit, trying to nickle and dime when you have a prosche at the end you will end up spending much more . and you can also save your self frustrations. Also you get markskis tech support , which that alone is worth the money.
It doesn't require the engine down just a lift... the easier I make it for the installer the less money you spend on labor... in the end you win...
thats my business model...
good luck
markski
![](https://www.6speedonline.com/forums/signaturepics/sigpic3357_8.gif)
2001 996TT 3.6L and stock ECU
I run 911tuning new pump kit on my car, very well made, nothing but top quality parts used in this kit, my tech had no problems installing it, car runs great could not be happier and it comes with great customer service from Mark, highly recommend it and agree with others save a buck spend 10 in long run...
If it wasn't for the time constraints I would definetly make my own kit but I have to have this done rather quickly so I think I will give this kit and Markski a shot and see what the hype is about. Saving money isn't always the priority.
#TeamAIM
#TeamAIM
