Vividracing VR750 turbo kit
Old 09-06-2011, 06:25 PM
ZIP22's Avatar
ZIP22 has a reputation beyond reputeZIP22 has a reputation beyond reputeZIP22 has a reputation beyond reputeZIP22 has a reputation beyond reputeZIP22 has a reputation beyond reputeZIP22 has a reputation beyond reputeZIP22 has a reputation beyond reputeZIP22 has a reputation beyond reputeZIP22 has a reputation beyond reputeZIP22 has a reputation beyond reputeZIP22 has a reputation beyond repute
Category: Engine - Power Adders
Price: $1
Location (State): CA
For sale is the complete VR750 996TT power kit. Has less than 5000 miles and is in great condition ready to be installed!!! Save close to $4000 from MSRP!
Description:
The 750 turbo kit is designed to use Garrett GT2860RS ball bearing turbos. The turbos have been spec’d out to produce quick turbo spool and optimal power gains throughout the RPM band. To increase torque, we developed the use of an external wastegate system. The Tial 44mm wastegates use band clamps with an external dump bypassing the stock exhaust system. Using an .8bar spring, the wastegates are very efficient for our use. The headers feature thick flanges to prevent warping. Using steel for the flanges prevents cracking due to the stainless material expanding under extreme temperatures. 10 gauge 304 stainless steel is used to build the header tubing. Low angle true merge collectors are put in place for proper exhaust flow producing optimal power gains. The collectors are also back purged when welded to finish off the high quality component. The headers are designed to bolt up to the stock block and mate with a Garrett T4 flange. For customers to retain their OEM replacement exhaust system, Agency Power uses an exhaust flange machined from 1018 steel which is then plated. The flange allows you to directly bolt on your exhaust system with no affects to the factory placement. The kit also includes the appropriate water lines, oil lines, and fittings to install your Garrett turbochargers.
These turbochargers are capable of 800 horsepower in total. To have this kit working properly, we recommend the below listed products. Any questions regarding installation, tuning, or about the products, please contact us. View Installation Procedures Here.
The VR750 Kit includes:
  • Garrett GT2860RS ball bearing turbos
  • Tial 44mm wastegates
  • Denso Iridium Spark plugs (brand new!)
  • K&N flat panel filter
  • Stainless Steel Headers for Garrett Turbos
  • Stainless Steel Dump Pipes for Wastegates
  • Steel Braided Oil Lines and Fittings
  • Turbo to Exhaust Adapters
  • Silicone Couplers Turbo to IC Piping
  • T4 Gaskets
  • Clamps and Bolt Hardware
Old 09-06-2011, 10:27 PM
dhahlen's Avatar
dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !
Pretty sweet setup, what did you end up putting down?
Old 09-07-2011, 03:07 AM
ZIP22's Avatar
At 1.2 bar it was around 600+
Full spool is at 2800rpms with these turbos!
Old 09-10-2011, 01:13 AM
ZIP22's Avatar
Up for the weekend crowd. Considering reasonable offers...need to make space, these must go!
Old 09-10-2011, 09:22 PM
roseylv's Avatar
roseylv is a name known to allroseylv is a name known to allroseylv is a name known to allroseylv is a name known to allroseylv is a name known to allroseylv is a name known to all
pm sent
Old 09-11-2011, 10:20 AM
unvmy996's Avatar
ZIP, did you install your 911 tuning kit ?
Old 09-12-2011, 05:59 AM
ZIP22's Avatar
The 850 yes
Old 09-14-2011, 03:55 PM
kongstang's Avatar
kongstang is infamous around these parts
Interested, please call at 405-410-5664. Or get me your number. Thanks, Kong
Old 09-18-2011, 12:03 AM
ZIP22's Avatar
Bumping up! Adding free shipping to the kit!
Old 09-18-2011, 01:28 AM
roseylv's Avatar
zip,
LMK if you'd like to entertain my offer. I'm still interested.
Old 09-18-2011, 07:27 AM
kongstang's Avatar
Please call or get me ur number. This site will not allow pm's unless u have posted over 15 times
Old 09-18-2011, 08:09 AM
ZIP22's Avatar
Originally Posted by roseylv
zip,
Sorry 4k for the turbo kit + intercoolers + ypipe is just too low but thanks for your offer
Old 09-18-2011, 08:10 AM
ZIP22's Avatar
PM sent
Old 09-18-2011, 12:08 PM
unvmy996's Avatar
Guys this is a really Good price on a good kit. someone will be saving ALOT of money..
Old 09-18-2011, 12:09 PM
grltnr's Avatar
grltnr is infamous around these parts
what kind of tune did you use for this?
Quick Reply: Vividracing VR750 turbo kit
