Want to build a high HP fuel system? Here is how...
#61
By perfect idle do you mean smooth and at stoich A/F. or just smooth, no hiccup, good coldstart etc?
Tony is still working on leaning it out, so we'll see what the final result looks like.
#TeamAIM
#TeamAIM
#64
Tony@EPL doing workkk
#TeamAIM
#TeamAIM
#65
I would like to see flow numbers of this vs a dual intank 044 set up. Im sure it would be very very close seeing as the pumps are the same and line is as well. the only thing i like better on the intank is that its very stelth when you look around you dont know it has a fuel system that is upgraded. Just my 2 cents.
#66
i dont know enough about the intank dual setups to be able to compare.
as far as stealth goes. i have a floor that goes over that whole contraption to keep it covered
#TeamAIM
#TeamAIM
#67
yeah - the pumps are the same. dont forget the other side of things. feeding each rail seprately and returing into an adjustable FPR. i think that is BIG and has alot to do with why the injector duty cycle is not even over 50%.
#68
Actually the Dual is the same, feeds both rails and returns to the FPR, unless i didn’t do it properly LOL. Yes the false bottom was always a good trick till the guys here started to look at the car with a magnifying glass to see how something so small and quiet would beat 800+hp cars LOL
you dont need a maginfying glass for my car. its yellow, sits on a 26.5" tall Mickey Thompsons and smells like corn dogs
#TeamAIM
#TeamAIM
#70
you dont need a maginfying glass for my car. its yellow, sits on a 26.5" tall Mickey Thompsons and smells like corn dogs [/QUOTE]
That is funny. Get your goodyear freckled corn dogs here!
#71
997tt ECU definetly give you more control when it comes to this and lots of other stuff.
#72
#73
No actually i have 2 044 pumps in the tank and they both feed the -8 line that runs up to the fuel rails
The in tank pump is now a feeder pump and the o44 is being fed by it even though it is not under psi (no head or fpr) it still is better then the o44 doing the sucking. The o44 was designed as a second high psi pump to feed fuel injection systems back in the day when it was all new. You know a 1bar spring and o44 upgrade.
