Want to build a high HP fuel system? Here is how...
Old 05-23-2012, 07:17 AM
#TeamAIM
  #77
Old 05-27-2012, 08:28 PM
k-ore's Avatar
k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !
Any updates on final rwhp ##s, Mark?
  #78
Old 05-29-2012, 07:30 AM
there are no final numbers yet.
car still idles rich.
on-off idle transitions are still rough sometimes.
#TeamAIM
  #79
Old 05-29-2012, 10:07 AM
UrbanHotrod's Avatar
UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !
im sure someone has this figured out.
  #80
Old 05-30-2012, 04:47 PM
bad107's Avatar
bad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond repute
why did you go with the setup instead of the integrated engineering design that submerges the two bosch 044 and has a higher tank capacity?
  #81
Old 05-31-2012, 01:11 PM
bad107's Avatar
also, how do you deal with the high amount of fuel that needs to be returned at idle and low/no boost driving? Why not put a hobbs switch to turn the other one on on 10+ PSI or something like that?
thanks!
  #82
Old 05-31-2012, 01:22 PM
Tim941NYC's Avatar
The FPR has no problem handling the fuel flow. Why add one more item to fail? And if it fails it will be quite costly..
  #83
Old 05-31-2012, 01:44 PM
bad107's Avatar
that is just a ton of fuel to be moving at idle...won't it likely cause a problem sooner or later? Hobbs switches looks pretty basic to me and seem to have been used in dual pump setups for a long time.
it will also keep the noise of the pumps down a lot
i am still trying to figure out why the $640 radium is better than the $300 integrated engineering model, which is bigger and submerges most of the pump for less noise.
  #84
Old 05-31-2012, 02:08 PM
when you submerge the pumps heat up fuel, fuel heats up pumps... they get noisy etc. from research i did two external pumps and a properly set up surge tank work best. i can not hear my pumps running with the trunk closed
our completely redone return (from each rail separately) setup has no problem returning the fuel at idle. we have played with the pressure on the FPR and we can bring it down quiet a bit from stock, if return wasnt enough we wouldnt be able to do that...
as long as the return line is not overwhelmed you don't need a hobbs switch on the other pump.
as far as surge tanks go i felt that the radium piece was a higher quality part so i went for that. the 300$ extra was a nominal premium when building a $3k fuel system. not to mention that with IE the price increases by 80$ if you plan on using alcohol fuels such as E85 so the price difference gets even smaller. you can use whatever surge tank you want or do dual in tank pumps like some ppl here.
#TeamAIM
  #85
Old 05-31-2012, 02:19 PM
bad107's Avatar
could this be done without dropping the engine? I really don't want to do that (or pay for that lol)
does it matter if you go horizontal or vertical?
  #86
Old 06-01-2012, 08:47 AM
its could but its a lot of work and i think having angine out would make this alot easier.
#TeamAIM
  #87
Old 06-08-2012, 09:52 AM
2.0 Bar on Alpha3076 Billets using E85. 797whp and 750wtq on Dynojet.
Injector duty cylce under 50% in peak tq.
#TeamAIM
  #88
Old 06-08-2012, 10:06 AM
c32AMG-DTM's Avatar
c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !
800 at the wheels, eh? Sounds pretty peppy. Congrats amigo.
Fine-tuning adjustments most of the way complete?
  #89
Old 06-08-2012, 10:12 AM
ysfg35's Avatar
ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !
congrats bro for the new numbers , am wondering about the IATs while running 2.0BAR , since you are not running water/methanol anymore , i guess you are reaching very high iats !! so is your ICs helping you ??
good luck bro
  #90
Old 06-08-2012, 10:18 AM
very impressive! are you going to try any new adjustments or your capping it off now?
Quick Reply: Want to build a high HP fuel system? Here is how...
