Want to build a high HP fuel system? Here is how...
#107
Hehe yup 18x8.5 and 18x12 R40 in wrinkle black. Binh has the HRE 542s..
#TeamAIM
#TeamAIM
#109
Best wheels you've had so far, IMHO. They look great against SY. Very nice choice, Mark!
#110
yeah i like them. they don't look as good as P40 or new P40sc but i needed an 18" wheel to run a stickier tire. Either R40 or some HRE comps. Wheels Boutique had an already made set of R40s in stock so there was no wait and I went for it.
#TeamAIM
#TeamAIM
#112
Good seeing you and the EV12 monster bro ! Sux we couldnt get a quick run off in the morning.
#TeamAIM
#TeamAIM
#114
Just wondering what you did to connect the new fuel line to the surge tank and return from the surge tank to the factory fuel hat quick connects?
I've got the fuel rails about sorted out. Just waiting on the new fittings so
I can tig them onto them.
#115
we made fittings for fuel rails. return into the surge and then overflow/vent from surge back to the stock location on the fuel hat. -6an line right over te stock tube with a nice clamp or put a bulhead there.
#TeamAIM
#TeamAIM
#116
Thats Kinda what I thought you did on the feed line and return lines to and from the surge tank. The -6 line fits on the factory fitting pretty tight. I might look into getting a few more 90 deg fittings and 2 bulkhead fittings to remove the quick connects on the factory hat.
Thanks again. Now all I need to find is another drivers side rail and some steel -6an fittings to weld to the rails
#117
Thats Kinda what I thought you did on the feed line and return lines to and from the surge tank. The -6 line fits on the factory fitting. I might look into getting a few more 90 deg fittings and 2 bulkhead fittings to reomce the quick connects on the factory hat.
#TeamAIM
#TeamAIM
#118
I ended up making custom rails and plumbed the intank pump to a bulkhead fitting at the fuel hat.
Just curious where did you end up mounting your pressure regulator.
I've got a couple of spots picked out. ( none are thta great )
Just wondering what you ended up doing with it.
