997.1TT EPL Flash on Dyno vs Stock
thanks ! haha stock ECU for now
#TeamAIM
#TeamAIM
997TT doesnt have a wastegate. It uses VTG to control boost. You datalog using a Durametric.
#TeamAIM
#TeamAIM
How much boost can the stock turbo's make at 100%?
VR Tuned says there are wastgate actuators? Confused now... Is this only for upgraded turbos?
http://www.vrtuned.com/tuning/upgrad...-making-boost/
There is no wastegate or wastegate control on 997tt which is why when you upgrade to GT30s you need to purchase an EBC to control the boost and not the stock ECU like 996tt does using a N75 valve. The turbos also have the DV (bypass valves ) which the ECU can open to protect the engine if needed.
#TeamAIM
#TeamAIM
Thanks ! Definitely a solid increase over stock, keep in mind this is not letting car adapt or anything. Dyno run, 10 min flash, Dyno run. It needs an exhaust now, you can just hear the air fighting the stock cats and mufflers on the way out.
#TeamAIM
#TeamAIM
Congrats on the Numbers.
#TeamAIM
#TeamAIM
it took 4 years, 5 sets of turbos, 3 sets of injectors, 3 fuel system revisions, 2 computers to get SpoolBus to this stage. i would like to get the 997 to 800whp.
#TeamAIM
#TeamAIM
HA we'll see what happens
#TeamAIM
#TeamAIM
Quick longer term update on my flash. I now have about a 1000 miles of enjoying the flash. Launch control works great, I've done some 3.5 0-60s on unprepped street. I have also made some 11 sec passes on the vbox. I quickly realized that stock clutch even with 12k babied miles will not be friends with new found power. I sourced a new uprated clutch and will be replacing it soon. Meanwhile I lowered the car on some Champion/H&R Springs and put some 7/15mm spacers on.
#TeamAIM
#TeamAIM
