Full iPod Control In a Pre 2009 Bentley GT
#46
Hi Cyril, that was what I was expecting to do. When I removed the CD, I noticed that the cable did not match. they must have discontinued the old Dice unit, and are now using this new one. Maybe you will get the older unit which will make your install much easier. For now, I am still searching for instructions on taking head unit out. Will keep you posted.
#47
Checking the AudioVox installation guide :
http://audiovox.diceelectronics.com/..._rev012312.pdf
Obviously you don't have the right cable included in your kit !!
See page 6 : you should have ordered A-DUO-102-AVW (and would have the correct cable).
Check what you have on your order.
Cyril
Cyril
#49
MontyFD, thank you very much.
Cyril, you were correct. I contacted the store who is selling this item via Amazon, and they confirmed that they sent me the wrong item. They should have sent DUO-102-AVW. Thank you for bringing this to my attention. I will be sending the incorrect unit back, and hope to receive the correct one Wednesday. I will keep you posted.
Cheers.
Cheers.
#50
Installed the Audiovox media bridge
After reading the forum, decided on the Mediabridge now produced by Audiovox.
Installation was so simple, pull out the CD changer using a set of Keys I got from Amazon as well, non specific removal keys, for radio removal fitting bentley , VW or audi. disconected CD connected media bridge. selected CD and voila, Iphone connection.
It took me a few minutes to understand how to switch from USB to Bluettooth.
I prefer now to connect to system via BT and play my audiobooks, or music , and if I need to charge phone connect cable, then I have to go back to phone and reselect play via mediabridge, but continues to charge.
I have not installed the BT microphone, yet, because dont know what and where do I want it.
so far, bought a sim card, added some minutes and use car phone when I need, and or transfer iphone to car. via forward function on iphone settings.
with the car buttons On the iphone you can only advance track, to next or previous, increase decrease volume, and mute. also with the microphone and bt, full function, but have not decided where to place microphone to get best results/. also car phone button will not run mediabridge bluetooth phone.
#51
#52
Yes I installed this unit as well. Factory Cd player would skip and stop playing at higher volumes. Great plug and play module. Works really well in BT Phone mode while connecting with your iphone. Does not work well with Android for anyone using the various Android phones. I installed the Mic in the left pillar of the windshield. Had to drop the glove box and routed the line behind the radio, under the steering column and up the pillar by pushing it into the space between the window molding and trim. Conceals it all perfectly.
#53
I'm Sure it's doable for someone technical enough to integrate the aftermarket mic input to the overhead oem mic output but for me was more practical installing the Mediabridge mic at the location I chose.
#54
Samsung S4 and the mediabridge
I can confirm that the Samsung S4 works very well with the mediabridge in my 2006 continental GT. Set up straightforward, bluetooth was a bit fiddly but works excellent once paired. Full control of tracks and phone through the track buttons on both the media console and steering wheel.
Money well Spent
Money well Spent
#55
Money well Spent
Money well Spent
#56
Hi Merdav, I connected through Bluetooth and it gives access to the phone as well as the songs album. I am using the audiovox mediabridge connected through the glove compartment by removing the CD player in the glove compartment. I think the model is MB 1502. Very easy to connect, just need the tools to remove the CD player and then its plug and play. Importantly, once the mediabridge is connected, within the first 5 seconds go to track 2 to engage the bluetooth menu and pairing. Sadly the screen on the bently only shows title 1...title 2 etc and not the full song details. More to do with dozy Bentley unit than the media bridge.
#58
I added the Isimple BT for the phone a while back, so I guess I already have everything the Mediabridge would offer. Thanks for responding so quickly.-MICHAEL
https://www.isimplesolutions.com/product.aspx?zpid=542
