Low Battery In Key
Old 07-23-2012 | 06:49 PM
bigshot's Avatar
bigshot is infamous around these parts
Low Battery In Key
Did any of you guys replace the battery in your main key when it got low or its rechargeable when you start the car with it ?
Old 07-24-2012 | 04:17 AM
stevenrmusic's Avatar
stevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond repute
The battery is easy to replace and is a CR2025 or some such, which is available at all camera stores, WalMart, etc. The kep FOB opens at the key holder short side (the bottom when looking at the buttons).
Old 07-24-2012 | 11:06 AM
Dr.Disaster's Avatar
Dr.Disaster is a name known to allDr.Disaster is a name known to allDr.Disaster is a name known to allDr.Disaster is a name known to allDr.Disaster is a name known to allDr.Disaster is a name known to all
Mine opened easily(with a knife scratching and scaring up the plastic) and closed with even more effort( mashing,pressing and forcing that little SOB to reseal). I think it was a 30 minute job.
After all my toil and sweat hitting the start button will occasionally cause the dash to read "key not found".??????? I have had to hit the lock or unlock to get the car to read the fob. Darn Bentley gremlins
Old 07-24-2012 | 11:24 AM
Link removed, info it contained was in error.
Old 07-24-2012 | 11:06 PM
bigshot's Avatar
Sweet ! took 2 mins to do. Great information has been shared. Thanks enjoythemusic !
Old 07-25-2012 | 08:54 AM
I might have exaggerated the difficulty of the job.
Old 07-28-2012 | 02:23 AM
bigshot's Avatar
And what do you do to make the key shine like new again ? Any special little trick ?
Old 07-30-2012 | 09:06 AM
No but the greatest damage occurred while learning on the valet key. I did a much better job on the primary key.
Old 08-02-2012 | 12:17 PM
jc_333's Avatar
jc_333 is infamous around these parts
Buy a new key? hehe
I nearly broke my key the first time as I didnt know how the cover came off and read the same site enjoythemusic posted. You dont have to remove side part but just use nose tip pilers at the rear key ring hole and twist cover off.
I still get key not found sometimes but battery is fresh...strange!
J
Old 10-05-2013 | 04:16 PM
67427's Avatar
67427 is infamous around these parts
Originally Posted by jc_333
Buy a new key? hehe
J
I have a 2008 gtc and to replace the key fob battery I did as described above, nearly broke the key the other way. For what is worth, one year later.
Old 10-07-2013 | 07:53 AM
J
I get this also. I mean I just started the car and it is running so how after seconds or a minute or two it says "key not found"?? This car has a shorter memory than I do.
Old 10-07-2013 | 10:00 AM
Same here with the rare yet occasional 'Key Not Found' warning. The 06 GT never did that, yet the 07 GTC does. Hmmm....
adnanm3
11-22-2023 03:43 AM
NIKAS
08-20-2019 08:53 PM
XLR82XS
10-05-2015 08:02 AM
holmesatx
09-02-2015 12:32 PM
