Intermittent Loss of Power
Old 03-31-2013 | 07:29 PM
Douyon's Avatar
Douyon is infamous around these parts
Final update after 2 weeks
Hello all,
Just wanted to say that the problem has definatly been resolved by simply changing the batteries. The car has been running great. I actually notice a big diffrence.
Thanks all for all your coments and support.
Old 03-31-2013 | 08:01 PM
jc_333's Avatar
jc_333 is infamous around these parts
Great news.
Worth to invest in a trickle charger to keep batteries in tip top shape. I normally plug mine every month or so to keep voltage levels up.
Old 04-01-2013 | 05:11 AM
stevenrmusic's Avatar
stevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond repute
Old 10-22-2018 | 08:20 PM
Bentley45's Avatar
Bentley45 is infamous around these parts
My intermittent power loss was due to a failed Bank 1 Exhaust Gas Temp Sensor. My car runs perfect after replacing that sensor. I also didn't get any lights or warnings on my dashboard I just hooked it up to my code reader and everything works fine now constant full power.
Old 01-09-2020 | 09:29 AM
Riccardo's Avatar
Riccardo is infamous around these parts
Battery change.
Hi. I’m having the same problem in my Bentley Continental GT, 2008. Power loss for just a couple of seconds then comes back on. Seems to be as I am trying to pull off. Did the garage change both batteries on your car?? I don’t use the car every day so could be my problem also.
Thanks.
Ric.
Old 01-09-2020 | 09:40 AM
Bentley45's Avatar
It wasn’t my battery’s It was my Exhaust Gas Temp Sensor bank 1. Replace it and you will be fine.
https://rover.ebay.com/rover/0/0/0?m...2F272901618570
Old 01-09-2020 | 01:42 PM
Riccardo's Avatar
Power loss
Thanks. I’ll check.
Guy Hitchin
Bentley
31
08-05-2024 12:53 PM
alwaysurfing
Bentley
09-11-2020 04:41 AM
dskippy888
Bentley
06-03-2019 08:55 AM
Quick Reply: Intermittent Loss of Power
