running gear fault on bentley gt
I get this code only when my ignition is on and i try to roll up my windows, it wont allow me to use the windows unless the car is running. if I attempt to use the power windows it throws a running gear fault and brake fault. when i start the car all faults go away and windows work perfect.
Any ever experience anything like this before?
i think its because my tpms sensors. i disabled the tpms system thru vag com. i was checking some fuses and i think i pulled the tpms fuse and the warning light came back on. it just started happening when the tpms was re-activated.
i am going to re-disable the tpms system thru vag com and see what happens.
have had a chance to put it on a reader. i just ordered a basic vag reader myself to see what it sais.
running gear fault seems to be a common issue with lots of vehicles tho. i have been readings its due to battery low, tpms and a couple of other things.
EMC2
Cayenne 955/957
09-07-2015 05:20 PM
markski@markskituning
08-24-2015 10:07 AM
